Vehicle: 1998 E300 estate, 2001 BMW M5, 1978 Moto Guzzi Le Mans II
Removing front tweeter grille?
Hi
Anyone know how to remove the front tweeter grille (behind the mirror). I cant get a blade in behind, so wondered what the proper way was. I am looking to replace with a component set.
Thanks
Hi
Thanks
To get to the tweeter first remove the door card then the door frame cover with the grill will pull off . The door card is held on by a star head screw behind the round cover at the bottom of the pull handle and another screw behind the door release leaver ,on the front doors there is a screw behind "SRS" badge' there is then one more behind the door latch cover , with these undone the door card is only held by snap clips and these will pull out. Then just peal off the door frame cove and release it from behind the door seal
