Old 07-02-2008, 01:13 PM   #1 (permalink)
squirrelonfire's Avatar
Date registered: May 2008
Vehicle: 1998 Mercedes E320
Send a message via AIM to squirrelonfire Send a message via MSN to squirrelonfire Send a message via Yahoo to squirrelonfire
Post BAS follows by ASR lights
Sometimes my BAS light come on, then follows immediately by the ASR light. I already changed my brakes 4 months ago, brand new brakes. The strange thing is sometimes the BAS/ASR lights come on, sometimes it doesn't. Sometimes they only come on after I pressed the brake pedal or run over a bump. Sometimes they just don't come on at all during my 16 mile trip to work. Sometimes they simply com on when I start the car.
I understand that I need to extract the code from my car to determine the problem, but is it possible to do the diagnostic yourself? Mercedes said they will charge me $125 to diagnose. I wonder if there's such cable or anything that I can hook up to the car to diagnose the code. Please help, these lights are super annoying.
squirrelonfire is offline   Reply With Quote
Old 07-02-2008, 01:29 PM   #2 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Hi, squirrel. Up in the DIY stickies you'll find one on this topic. This alert has nothing to do with worn brakes. Rather, with those symptoms I'd replace the brake light switch. You don't need codes, cables or anything else. Cheap part, easily replaced, problem solved.
Take care and enjoy the ride,
Greg
Meister Eckhart
Old 07-02-2008, 03:06 PM   #3 (permalink)
Date registered: Apr 2007
Vehicle: 2001 SLK 320(96K Miles), 2002 E320 Special Edition(113K Miles)
And just if you're wondering - it's a cheap part. Used to be less than $20.
Only two thing are infinite, the universe and human stupidity, and I'm not so sure about the former.
Albert Einstein
Honest politicians (and lawyers) are like UFOs. Most people believe that there must be some out there somewhere, but nobody has yet been able to prove their existence.
Kobus is offline   Reply With Quote
Old 07-02-2008, 03:17 PM   #4 (permalink)
I went to the DIY section but the pictures taken were too poor in detail. I think i might have to get the DVD mechanic manual from mercedes now.
Old 07-02-2008, 03:56 PM   #5 (permalink)
ohlord's Avatar
Once you get down under there
you will see it is easy
Step 5
i don't think the dvd explains it any better rhen just moving the steering wheel all the way up and back and kust following what the diy tips are.The dvd does not hold your hand and guide you along,sometimes you need to trust you intuitive powers and just get er done.
you only need to do the steps to remove the under panel and then follow along to diy the switch.
a good flash light,helps
ohlord
Old 07-03-2008, 04:25 PM   #6 (permalink)
Did this website just pirate that $160 DVD I just ordered from Mercedes?
Old 07-04-2008, 12:51 AM   #7 (permalink)
KADE's Avatar
Date registered: Jan 2006
Vehicle: E-320/ 2000
squirrelonfire Its a simple job, if you follow the DIY the only hardest part is removing the lower dash...and really thats easy just removing screws, the part itself honestly takes 5 minutes or less to put in place...just follow the DIY
And I almost forgot.. Ohlord left out the most important part-make sure you have some Advil handy for your back!!! because you do have to lie sideways to get under there.
KADE is offline   Reply With Quote
Old 07-04-2008, 09:21 AM   #8 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
Only part of it. You're getting a whole lot more.
SLK230 BAS ASR Brake Lights Blown Fuse brwnfood34 R170 SLK Class 2 03-25-2008 01:55 PM
OK! New problem! Just fixed the asr light, today, both the asr and the abs lights has come on! Cabbe W140 S-Class 15 09-30-2006 07:10 PM
no brake lights bas/asr warning lights on cward2105 W123 E,CE,D,CD,TD,TE Class 3 08-12-2006 10:34 PM
ABS & BAS ASR lights on ccrobins The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 06-30-2006 02:28 AM
My BAS and ASR light come on. Pej D. R170 SLK Class 3 08-25-2002 03:43 PM
