Old 07-02-2008, 01:03 PM   #1 (permalink)
Date registered: Jan 2007
Vehicle: 1997 E 320, 1985 500 SEL
Unhappy Misfires Help!
I have a 1997 E320 inline 6 w/108k and I’m having misfires. The check engine light comes on with the check engine electronics. The code for the check engine light is for bank one O2 sensor and multi misfires. I have been to a few mechanics that works with Mercedes but so far just a lot of money spent without helping the problem. Thus far, the MAF, O2, cam, and crank sensor have been replaced. Also, the fuel filter has been replace, the fuel system was cleaned and checked, and the engine was compression check @ around 180 each cylinder. Just looking for any pointers that maybe help me with my problem.
spainhour5 is offline   Reply With Quote
Old 07-02-2008, 03:53 PM   #2 (permalink)
Musikmann's Avatar
It sounds like you have a bunch of mechanics guessing about the problem and by process of elimination throwing parts (and your money) at the car. By the way, this is my day to state the obvious...
Most towns have an independent garage owned or operated by former Mercedes-trained techs. I'd look for one of those before spending any more money.
Hopefully someone here will have your answer, and good luck!
Old 07-02-2008, 04:16 PM   #3 (permalink)
ohlord's Avatar
Has
anyone checked the cat converters?straight 6 only has one bank of cylindersThe multiple misfires mean they all are affected which should lead them or someone to conclude your cat has gone bad.Test it and where are you located ? A universal cat can be spliced in.
ohlord
Old 07-02-2008, 07:00 PM   #4 (permalink)
Date registered: Dec 2007
Vehicle: E320 4 Matic 2001
I had a misfire code for cylinder 3 and finally it was the coil for cylinder 3 that was torqued a bit too tight.
Hi Fi is offline   Reply With Quote
Old 07-02-2008, 07:12 PM   #5 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Hey, HiFi, his appears to be a wander set of misfires, if it was isolated that would help him out a lot.
spainhour5, I would guess that someone has checked the plugs, wires and connectors? If not those are worth a look and I agree with ohlord that a plugged up cat can cause all manner of issues. If the car can be safely driven go for a good ride and then stop (leave it idling) and look under at the cat. Plugged ones will run hotter and I have even seen them glow so it's better to do this at night. Glowing would mean it is highly suspect, not glowing would only mean it's not definite but still suspect.
And please complete your online profile re: vehicle and location as that is useful information.
The last thought I'd have is to check the engine wiring harness, older models sometimes see those creeping in as issues. Major harness issues in the W124 series, from what I have read as the 210 population has aged some of the older ones have had problems.
Good luck and keep us posted,
Greg
Meister Eckhart
Old 07-02-2008, 07:19 PM   #6 (permalink)
MaxVon's Avatar
Date registered: Dec 2006
Vehicle: 2000 E55 AMG
ohlord
+1
I went the plugs, wires, coils route when my E55 threw misfire codes despite the advise of a sage MB tech. I figured no way a catalytic converter could be bad and still pass CA smog, right? I was wrong.
MaxVon is offline   Reply With Quote
Old 07-02-2008, 07:36 PM   #7 (permalink)
Musikmann's Avatar
Originally Posted by MaxVon View Post
+1
Max,
Funny you should mention that. I was talking with the MB tech who replaced my cats today and he said several of his customers (when he had his own shop in Ohio) ran with gutted cats. Those cars all passed the state emission inspection.
Old 07-02-2008, 10:15 PM   #8 (permalink)
thebenzmane55's Avatar
Vehicle: 2000 E430 summer and 1988 420sel for the winter
The M104 motor is famous for bad engine harnessess, check to see how crispy your wiring is, take a razor blade and cut open the harness, just slice the wrapping and check the wires, i bet the coating has come off and therefore causing your misfiring
thebenzmane55 is offline   Reply With Quote
Old 07-03-2008, 09:43 AM   #9 (permalink)
Date registered: Aug 2007
Vehicle: W210 1998 E430
X2 - though I thought the wiring harness issue was more with W124 chassis and the M104 combo, not the W210/M104 cars? Could be wrong though.
Benzboy210 is offline   Reply With Quote
Old 07-03-2008, 10:33 AM   #10 (permalink)
gregs210's Avatar
The W124 is well known for the engine harness. The W210 has been far better but there are a few reports of it, particularly with the early L6 engine and MYs.
Engine Misfires opbigdave W210 E50 AMG, E55 AMG 3 05-04-2007 06:08 AM
P0300: Misfires gm_bigj W220 S-Class 9 11-16-2006 12:21 AM
CL 600- Misfires HELP! Ditty W215 CL Class 5 04-23-2006 01:43 PM
diesel misfires ..happens on and off crazypolok W124 E,CE,D,TD Class 0 04-04-2006 08:32 PM
Fuel Injectors and misfires MattH R170 SLK Class 0 08-12-2001 05:20 PM
