Old 07-01-2008, 11:35 PM   #1 (permalink)
Date registered: Aug 2004
Send a message via Yahoo to arnel_lim
Wheels for W210 and W211
Will the stock wheels on a 2006 E350 fit on my 1999 E430? My brother-in-law bought some new rims/tires for his E350 and is practically giving me his old set. His old tires only have 500 miles on them and I'm in need a new set of tires for my E430. If his rims fit, I'm all good!
arnel_lim is offline   Reply With Quote
Old 07-01-2008, 11:51 PM   #2 (permalink)
raymond-'s Avatar
Date registered: Jan 2004
critical specs: offset, wheel thickness (through the bolt hole to back surface),
wheel width, bolt length, bolt diameter, ball seat radius.
your model uses 12mm bolt diam, 12mm ball seat radius, prob 1.75" bolt length,
7" wheel width, ET38.
E350 uses 14mm bolt diam, 14mm ball seat, guessing 1" bolt length, 8-8.5"
rim width, and ET36
so, it may, but you need to post the specs on the new rims to determine
rub potential. your lugs are too small and will result in poor ball seat contact.
....though there is a hybrid bolt available, grafting 14mm ball seat to 12mm
diameter bolt. you'll also need to select bolt length, after you measure the
thickness of the wheel at the bolt.
raymond-
47º34'N 122º18'W
raymond- is offline   Reply With Quote
Old 07-02-2008, 03:16 AM   #3 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Hey arnel. There is a sticky up above on this exact issue. Short answer: with the custom lug bolts noted in the sticky the wheels will fit. The bad news? The tires will rub in the front. So you will either need new tires or spacers and then you'll have different lugs front and rear.
My recommendation: if you like the wheels get them, the lugs and ... new tires that fit. Since you mention needing tires, though, these wheels won't help you.
Take care and enjoy the ride,
Greg
Meister Eckhart
Will W210 wheels fit on W211? ProV1x W210 E-Class 10 07-02-2008 12:07 PM
W211 Wheels on W210 PJH The Discount Tire Direct Tire, Wheel, Brake & Suspension 10 06-25-2007 02:45 PM
w211 to w210 wheels odario The Discount Tire Direct Tire, Wheel, Brake & Suspension 3 06-07-2007 04:31 PM
W211 wheels on a W210?? archander The Discount Tire Direct Tire, Wheel, Brake & Suspension 5 01-19-2006 10:51 AM
W211 Wheels on a W210 islandiron W210 E-Class 6 08-25-2004 10:06 PM
