» Site Navigation
» Other Sites
Old 07-01-2008, 06:56 PM   #1 (permalink)
Date registered: Apr 2008
Vehicle: 1999 E320W, W210 Obsedian Black Metalic
Post wheel locked in
Hello all,
I have a 1999 E320 and I was planning on changing my brake pads and after unscrewing the wheel bolts I couldn't take the wheel off. the same goes for all wheels. I checked the owner's manual but they didn't mention anything about having any extra security (anti-theft)
anu suggestions are appreciated
Thanks in advance
raed_jan is offline   Reply With Quote
Old 07-01-2008, 08:32 PM   #2 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
Hello Raed Jan and welcome to the forum. Please take a moment to complete your user profile with your vehicle model and year, and your location.
Your wheels have bonded to the hubs. This happens if they've been on for a very long time, and salty roads make the problem a lot worse.
Screw the bolts in, but not all the way; leave them a few turns loose. Then hold a piece of lumber against the tire and smack it with a hammer. It will probably take several good hits.
Old 07-06-2008, 09:05 PM   #3 (permalink)
Thanks Matt, Wheels are off
Matt,
How can I be more thankful to you? your advice worked perfecly and wheels were off with 5 or 6 smacks of my 5 lbs sledge hammer (on a piece of lumber ofcourse) you were correct about the wheels and hub being bonded because of salt.
Many thanks also to the gentleman who posted the pads and rotors change DIY.
Lessons learned are the following:
1- grease up the hub before winter
2- thorough check to the underside. a wash/dry/grease shall be a must
3- do lots of reading before starting any maintenance job
Thanks a million Matt
Old 07-20-2008, 11:48 AM   #4 (permalink)
makarona78's Avatar
Date registered: Jan 2007
Vehicle: 2000 E320. 2002 745Li Lemoned, 2008 535i
Hello guys , How can i tell if i need 1 pin or 2 pin brake pads , i have a 2000 E320
Thanks
makarona78 is offline   Reply With Quote
HELP!Steering wheel locked and some kind of oil is leaking! wuyichao W163 M-Class 11 04-21-2007 01:36 PM
steering wheel locked Benzat17 W203 C-Class 7 01-29-2007 05:57 PM
Locked Steering Wheel foom W124 E,CE,D,TD Class 12 10-19-2006 09:52 AM
Locked Steering Wheel and Ignition truviking W201 190E, D-Class 6 09-23-2006 08:01 PM
Steering wheel locked Freddie from DC R170 SLK Class 0 08-17-2001 08:38 AM
