Will the 1998 Bose Component speakers work in other cars, say for instance in my 1994 Q45T which also uses a Bose Component set up? I do know, Bose designed speakers around each cars cabin structure, but I wanted to know if I can by pass that structure and still use the Bose speaker in the Benz in another car which also uses Bose?
3. Paul Hamm, Gymnast: I owe a lot to my parents, especially my mother and father.
"I would hate to see a VIP car with anything but a Japanese motor. It's like putting fried chicken in your sushi :d2td" Nico Member Comment
Hey, sly. So long as the resistance is the same and you maintain proper polarity, I don't know of any reason they should not work in another application.
Hard to say. I'd check and see if the ohms are the same for the Bose MB speaker as it is/was for the Infinity. The wattages of the respective amps might come into play as well.
