» Site Navigation
» Other Sites
Old 06-26-2008, 07:27 PM   #1 (permalink)
Date registered: Apr 2007
Vehicle: 2001 SLK 320(90K Miles), 2002 E320 Special Edition(112K Miles)
Replacing Vent Wheel Lights
I've now finally gotten around to replace the lights on all three vent wheels and have created three separate sets of instructions.
Mine all went within a few weeks of each other, so when the first one dies, it may be worthwhile to replace them all. Or at least do both the passenger side and the center vent, since there are some procedures common to both. That way you also ensure that they have the same light intensity.
I think that the pre-facelift model does not have the vent lights? It may make a nice upgrade if you can find the face-lift vents in a scrapyard - assuming of course that they will fit.
Mr Moderator, maybe you can unstick the original one and stick this combined post?
Only two thing are infinite, the universe and human stupidity, and I'm not so sure about the former.
Albert Einstein
Honest politicians (and lawyers) are like UFOs. Most people believe that there must be some out there somewhere, but nobody has yet been able to prove their existence.
Kobus is online now   Reply With Quote
Old 06-26-2008, 07:41 PM   #2 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
Very good work. However, I do have a suggestion that you could add, if you want.
You show the removal of the wood dashboard trim on the passenger side in two of those entries. You should put a note in each saying that if you need to change both bulbs, do the other before you put the wood trim back in place.
Of greater concern, I can't seem to find the old thread in the DIY. What's the URL of your thread?
Old 06-26-2008, 07:59 PM   #3 (permalink)
Matt,
It's under Body, trim, lighting, etc., as the first sticky under the Lighting heading. The person who added to the stickies obviously had a better command of English than I have and called it "DIY: Courtesy Light Replacement, Left Side HVAC vent control (w/pictures) " (Greg?)
Regarding the trim, I sort of assumed that anybody will first read the information and notice that the first part is the same, and not go through the replacement just to remove it again. But maybe it is a good idea that you have mentioned it.
Old 06-27-2008, 07:37 AM   #4 (permalink)
Thanks. I made the change.
Old 06-27-2008, 10:38 AM   #5 (permalink)
I forgot to mention that I did not loose the radio presets - only had to re-enter the radio code.
Old 06-27-2008, 10:53 AM   #6 (permalink)
Musikmann's Avatar
Thanks for the write-up Kobus.
Pictorial DIY - replacing driver side vent wheel light Kobus W210 E-Class 18 06-19-2008 01:06 AM
Heating and Cooling Vent Lights shurik W202 C-Class 0 03-21-2008 02:03 PM
Vent open/close dial lights mfagus W124 E,CE,D,TD Class 12 11-16-2007 07:26 PM
A/C to vent at stop lights Robschaef W124 E,CE,D,TD Class 4 09-17-2006 12:47 PM
need help, ANY, on replacing air vent on 190e!!! Guest (MBNZ) W201 190E, D-Class 2 11-04-2001 11:04 PM
