» Site Navigation
» Other Sites
Old 06-04-2008, 08:16 PM   #1 (permalink)
Date registered: Nov 2006
Vehicle: 2002 e320
creaky driver's seat
i Hve an annoying creak when i sit in the driver's seat. it sounds like a creaky spring in the cushion. any suggestions on how to fix it? thanks, paul
pvel is online now   Reply With Quote
Old 06-04-2008, 08:59 PM   #2 (permalink)
Premium Member
acarter53's Avatar
Date registered: Dec 2006
Vehicle: 2001 E430 Sport in Desert Silver and 2002 C320 Sport Wagon in Arctic White
Premium Member
Send a message via Yahoo to acarter53
pvel,
A small amount of investigating will need to take place if you plan to DIY. You should remove the seat from the car and take a look from the underside. You may be able to duplicate the sound by applying pressure to the top of the seat. The issue my be obvious. Let us know what you find.
E430 Sport
2001 E430 in Desert Silver with Sport Package, COMAND, Xenon Lights, Rear Sunshade, Heated Seats. Added K40 Stealth Radar, 30% Tint, XM Radio! www.premierbasement.com
acarter53 is offline   Reply With Quote
Old 06-05-2008, 09:40 AM   #3 (permalink)
Date registered: Mar 2008
Vehicle: 1999 E320
My 1999 e320
Makes the same popping noise when making turns...it is annoying but I can't locate the source...must be a design problem. Let us know if anyone can solve the problem.
Thanks
mistertonyn is offline   Reply With Quote
Old 06-05-2008, 09:51 AM   #4 (permalink)
meooem1's Avatar
Vehicle: 99 e320 wagon gold/tan 96K miles
there is a tsb on this problem and a retrofit piece to fix the problem. i think it is like $200 in labor if my memory serves me right. i never had it done though. you will have to do a search for the tsb number.
meooem1 is offline   Reply With Quote
Old 06-05-2008, 10:00 AM   #5 (permalink)
ohlord's Avatar
Vehicle: 99 e320 wagon,bmw,vw,mgb,mg midget,subaru wagon
Don't
sit in the drivers set
ohlord
Old 06-05-2008, 07:13 PM   #6 (permalink)
Vehicle: 1999 E320
$200 for labor to fix this!!!! Maybe I'll live with it...
You got to be kidding me....what is tsb anyway?
Old 06-10-2008, 01:09 PM   #7 (permalink)
Date registered: Mar 2007
Vehicle: 2002 E320, Black on Black,
Did you have this done at Mercedes Benz of South Bay? Mine are doing the same thing, it rocks back when I take off, rocks forward when I slow down, with a "popping" noise.
tsb:technical service bulliten
rmeneses is offline   Reply With Quote
Old 06-10-2008, 05:52 PM   #8 (permalink)
meooem1's Avatar
TSB= technical service bulletin. they are problems that mercedes acknowledges because a lot of people have had the same problem, but they don't cover unless you a mercedes warranty. there was no way i would pay 200 to fix this problem. i opened up the back of the seat and hosed down the area with a nice smelling lube. works great for about 6 months..then hose it down again. just got my wagon, same damn problem....where is the lube? anyone interested in my sedan.....
Old 06-11-2008, 02:50 PM   #9 (permalink)
thesteveco's Avatar
Date registered: Jun 2008
Vehicle: 2001 E320 Wagon
Same problem on mine - if I gun it from a stand-still, but not much worse than that. I can reproduce by rocking back and forth when stationary. I figured it was just a clip or something.
Interesting to hear that others have the problem... guess it's time to do some research into that TSB.
thesteveco is offline   Reply With Quote
Old 07-06-2008, 02:51 PM   #10 (permalink)
Vehicle: 1999 E320
It is hard to believe that they can not get that right...
I hear pops and rattles in the rear seating area as well...and my commute car (Accord) is rock solid ...NO noise.
Driver's seat will not go back jbowen1094 W208 CLK Class 6 02-19-2008 11:30 AM
Seat belt/buckle problem: 91 420sel driver's seat neevy W126 S,SE,SEC,SEL,SD,SDL Class 11 11-04-2007 09:08 PM
Why is removing the driver's seat not like the passenger seat? Halfwise W123 E,CE,D,CD,TD,TE Class 12 10-22-2007 08:48 PM
Driver's seat deteriorating silver00E320 W210 E-Class 4 12-08-2006 08:55 PM
Squeaky driver's seat mcbaes72 General Mercedes-Benz 8 11-01-2005 07:11 AM
