Old 06-03-2008, 05:57 PM   #1 (permalink)
ETP
ETP's Avatar
Date registered: Sep 2007
Vehicle: 99 E-430 w/mods 98 E-320
Code P0341
98 320 78K
Camshaft Position Sensor Circuit range performance...
replace the sensor? I have occasional rough idle on start up.
Can you DIY this part?....thanks
ETP is offline   Reply With Quote
Old 06-03-2008, 06:09 PM   #2 (permalink)
ohlord's Avatar
autohausaz.com
cheap,pick up a filter or something if under 50 bucks so you can get the free shipping.Located on passenger side head at the front of the head.Easy diy.
check that it is fully plugged in before you declare it dead,and that all the wires are in good shape.
Old 06-03-2008, 06:15 PM   #3 (permalink)
ETP
ETP's Avatar
As always ....Thanks
Old 06-03-2008, 06:15 PM   #4 (permalink)
Musikmann's Avatar
CPS & CPS
Sorry if this has been explained before but can someone briefly explain the difference between the camshaft position sensor and the crankshaft positon sensor?
Thanks in advance,
MM
Old 06-03-2008, 07:37 PM   #5 (permalink)
ohlord's Avatar
Crank
sensor measures speed of the crank shaft so accurately that it can tell what cylinder is missing if it is missing by noting the change in flywheel speed.So it is used to regulate the firing of the plugs.Cam sensor among other things notes cam position thus the valves to help regulate fuel injection.So they sort of go hand in hand ,but have different symptoms when they fail or start to fail.And we all know which is the more common failure item.
ohlord
Old 06-03-2008, 08:01 PM   #6 (permalink)
Musikmann's Avatar
Thanks much ohlord
Old 06-19-2008, 11:07 AM   #7 (permalink)
etp,
just wondering if replacing your sensor did the job. The same code's coming up for me, and won't clear even after having replaced the sensor. Also, did you notice your selector freezing up and a bas/esp light coming on?
SinesurfR is offline   Reply With Quote
Does the Audio 20 have a radio code? - NOT a code request!! TomTanderson Audio & Telematics Forum 2 02-09-2008 03:00 AM
PO442 code caused buy a PO455 w/o code ? gw17625410 General Mercedes-Benz 3 06-14-2007 01:06 PM
SLk runs, drives but still get OBD II P0341 sealworld R170 SLK Class 1 03-21-2007 08:20 PM
Trouble Code P0341 - effect? oztds R170 SLK Class 7 01-15-2007 05:46 AM
Body Code? Equipment Code? Leeyore W123 E,CE,D,CD,TD,TE Class 4 07-19-2006 11:13 PM
