Old 10-04-2008, 10:27 PM   #21 (permalink)
Date registered: Apr 2007
Vehicle: 2001 SLK 320(96K Miles), 2002 E320 Special Edition(113K Miles)
More codes
Here's some more codes that are not in Greg's original list:
B1010 Low voltage Terminal 30E
B1040 CAN - Communication error with engine control unit
B1041 CAN - Communication error with the traction control unit.
B1100 Control line deactivated : PSE/CL CF ATA
B1111 CAN communication fault with TELEAID control unit
B112D AIRCON : receive signal has short circuit to ground
B1133 Airbag module or tension to low
B1453 Fresh air/recirculated air flap actuator
B1712 Alarms triggered via left front door contact switch
B1217 Rain Sensor
N1140 CAN Bus Error
N1141 Set to actual configuration of DB2 ring differs
Only two thing are infinite, the universe and human stupidity, and I'm not so sure about the former.
Albert Einstein
Honest politicians (and lawyers) are like UFOs. Most people believe that there must be some out there somewhere, but nobody has yet been able to prove their existence.
Kobus is offline   Reply With Quote
Old 10-20-2008, 12:52 PM   #22 (permalink)
Date registered: Sep 2008
Vehicle: 1997 E320
codes after replacement of water pump
I recently replaced the water pump on my 97 e320 and now have the check engine light on (engine electronics) with the code P0170. Is this coincidence or are the two related? Any hints would be greatly appreciated.
Kevin
kb320 is offline   Reply With Quote
Old 10-20-2008, 03:05 PM   #23 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Kevin
Welcome to the forum, Kevin. Please click the user cp link and complete your BW profile re: vehicle and location as that is useful information.
Just a tip, here, but it's always better to create a new thread than hijack one of the DIY threads with a question.
Hopefully one of the mods will see this and migrate it to it's own thread so we don't clutter up this DIY one.
Did you replace the WP or have it done? If the latter, take it back to the shop and have them fix it, it's their responsibility. They could have knocked loose a connection.
If you did it, check the wires for the MAF, make sure the connections are all clean and dry and firmly plugged-in. If they are and the car is running okay then clear the code and see if it returns. If it does go to autohausaz.com and order a new MAF, that's likely the problem.
Take care and enjoy the ride,
Greg
Meister Eckhart
Need list of codes Rappidtrac W163 M-Class 2 10-18-2006 05:02 PM
Complete list of error codes? Where? biodieseler W210 E-Class 2 10-16-2006 02:00 PM
Check Codes reoterq W210 E-Class 3 10-06-2006 11:30 AM
Does anyone have the list of colour codes for plastic details inside the car? Donald R129 SL Class 1 04-23-2005 10:36 AM
Found this list of MB fault codes, thought you might like it J-bird W163 M-Class 0 02-19-2004 09:39 AM
