Old 06-01-2008, 10:33 AM   #1 (permalink)
Date registered: Jun 2008
Hi side access valve location?
Can anyone help me with the location of the hi side access valve location on my 98 E430? I have a leak pressure tested system with 300 lbs nitrogen an i lose 50 lbs is 5 mins. Need to locate for proper evacuation. Want to be sure of the leak by having both sides hooked up to my test manifold? Thanx in advance.
Chauncey is offline   Reply With Quote
Old 06-01-2008, 10:51 AM   #2 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
It's at the top-left corner of the condenser, covered by a small plastic panel on the auxiliary fan shroud.
You can see it here:
http://www.benzworld.org/forums/w210...tallation.html
post #3, second image.
ECU location - access Fourdiesel GL Class 0 11-06-2007 03:58 PM
Location EGR valve? matteus W210 E-Class 4 04-06-2006 11:05 AM
Side turn signal bulb access Barry McCoy W163 M-Class 9 01-24-2004 10:25 PM
Passenger side corner light access raucuspc W124 E,CE,D,TD Class 2 12-06-2003 07:29 AM
EGR Valve Location?? Icebergb28 W163 M-Class 0 11-13-2003 08:28 AM
