Old 05-31-2008, 01:26 PM   #1 (permalink)
Date registered: Dec 2007
E430 Wont Rev
Car was running fine, changed oil and filter and air filter, didnt touch anything else, car now has no power and wont rev, any ideas?
nameddriver is offline   Reply With Quote
Old 05-31-2008, 01:43 PM   #2 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Sure, but instead of guessing my first suggestion would be to check for codes. Please complete your profile re vehicle and location, too as that is helpful information. If you are in the US Autozone and other places will read the codes for free, that will give us something to go on.
Take care and enjoy the ride,
Greg
Meister Eckhart
Old 05-31-2008, 04:26 PM   #3 (permalink)
ohlord's Avatar
Check oil level
then check that when you had the air box off the you did not unplug the maf harness or pull a vacuum line by mistake.
ohlord
Old 06-01-2008, 10:18 AM   #4 (permalink)
live in wales in uk, checked all the above, going to try disconnecting the battery.
Old 06-02-2008, 01:21 PM   #5 (permalink)
ohlord's Avatar
What kind of air filter did you install?
and remember after you hook the battery up again,you need the radio code and you need to start the car and turn the steering wheel all the way left to all the way right and back a few times to center the steering wheel angle sensor.
Was the oil level OK?Did you check that the maf was fully plugged in and that all the hoses for the intake are in place?
Any check engine light?
ohlord
2003 ML500 wont rev just cuts out AdamNEUK W163 M-Class 8 03-03-2007 12:48 AM
Wont rev just cuts out AdamNEUK W163 M-Class 0 02-19-2007 02:21 AM
my 500 sel idles but wont rev aussiesmg W126 S,SE,SEC,SEL,SD,SDL Class 1 09-12-2004 10:59 AM
500 sel wont rev in gear aussiesmg W124 E,CE,D,TD Class 1 09-12-2004 10:35 AM
81 Mercedes 380sl intermittently wont rev Guest (MBNZ) R/C107 SL/SLC Class 0 01-21-2001 08:22 PM
