» Site Navigation
» Other Sites
Old 05-30-2008, 02:23 PM   #1 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Hood opening and location of the CPS Sensor and Pre-Cat O2 sensor
Hey, folks. I added this PDF to the CPS sticky but since it has other info I thought it might be useful as it's own thread.
It details the trick on opening the hood to vertical and then helps locate the CPS and as it turns out, also the pre-cat O2 sensor for Bank 2.
Take care and enjoy the ride,
Greg
Installation of a CPS sensor. With pictures! earthwonder W210 E-Class 69 08-08-2008 04:51 PM
CPS ( crank position sensor ) Red, W220 S-Class 0 04-09-2008 05:24 PM
Where is the CPS (Crankshaft Position Sensor)? lnguyenh R129 SL Class 6 03-24-2008 08:30 AM
95 E200. Oil sender sensor location, brake pad sensor location, engine code? cubicincubi W124 E,CE,D,TD Class 2 01-04-2006 08:07 AM
02 sensor bank 1 sensor 2 location sling_lphie W163 M-Class 0 07-27-2004 07:08 PM
