Old 05-27-2008, 06:05 PM   #1 (permalink)
Date registered: May 2008
Vehicle: 1999 E300 DT
1999 E300 DT (TD) suddenly quits
I've recently purchased a 1999 E300 turbodiesel, 129000 km, which runs beautifully, but twice now has suddenly quit during hard acceleration. The engine has died - no hesitating, just sudden silence with the check engine light on. It cranked but would not start immediately after, but when left to sit for a minute it started and ran normally. The codes were p1220 (fuel delivery) and p1223 (rack). My local mechanic, who is a genius with older diesels, has no experience on this generation and is stumped. I've had VW and Audi diesels, but everything fuel related was strictly mechanical with them.
Any ideas?
A couple of other questions - when the engine is cold the injector pump or something in that area of the engine is noisy. When I first heard the noise I thought it was a bad bearing. After the engine has run for a minute or so the noise stops, so I assume it's related to the adjustment of injection timing when cold. Has anyone else heard this sound? Is it normal?
When I accelerate hard I get a lot of black smoke. The engine produces none when starting or running gently. Is there a way to reduce the amount of fuel injected when the turbo is producing a lot of boost? Also, I thought the E300s had a particulate filter.
Thanks,
bpraddatz is offline   Reply With Quote
Old 05-27-2008, 08:40 PM   #2 (permalink)
Kajtek1's Avatar
Vehicle: E300DT/320cdi ML320/55
Welcome to the forum and welcome to the computer with wheels you have trouble with.
From what I know you can't do anything to engine management without Star-mark computer, what is high-tech shops only item.
Than those engines at this mileage are famous for having fuel system orings deterioration. Check the archive for more topics and to start see the clear tubings connecting injector pump with other appliances. If you see air bubble in them that might be your answer.
Kajtek1 is offline   Reply With Quote
1999 e300 TD questions mackbenz W210 E-Class 6 11-24-2007 10:50 AM
1999 E300 Horn Problems jlonda W210 E-Class 6 04-15-2007 04:25 PM
F/S 1999 E300 Turbo Diesel Steven For Sale, Trade & Wanted Items 1 08-25-2005 01:52 PM
1999 E300 Turbo Diesel archander For Sale, Trade & Wanted Items 1 08-06-2005 11:42 AM
1999 E300 TD vibrations nkhimani W210 E-Class 1 10-20-2004 04:32 PM
