Old 05-08-2008, 10:44 PM   #1 (permalink)
mb333's Avatar
Date registered: May 2008
Vehicle: 1997 MB E420
Wink Check Engine- Engine Electronics...
I bought this 1997 E420 with 73K miles on it about 1 month ago and I was sitting at a drive through and the "CHECK ENGINE-ENGINE ELECTRONICS" light came on and will not go off. Does anyone who what this might be or has had the same thing happen to them? Thank You.
mb333 is offline   Reply With Quote
Old 05-08-2008, 11:04 PM   #2 (permalink)
Date registered: Dec 2006
Vehicle: 1997 E320, 1997 S320
autozone will check your codes for free. take your car there tomorrow, tell them to write down the code for you on a piece of paper, and also tell them to erase the code. then write the code on here, and someone here will let you know what;s going on.
tirona is offline   Reply With Quote
Old 05-08-2008, 11:15 PM   #3 (permalink)
mb333's Avatar
I appreciate your reply's. Is it safe to drive the car while this message is on?
1997 E420
Old 05-08-2008, 11:24 PM   #4 (permalink)
ohlord's Avatar
yes
as long as it is not blinking.
Had you just filled up?Check the fuel cap is on correctly.Then get the code or codes per above and post them.
ohlord
also never top off when you fill up.
Old 05-08-2008, 11:39 PM   #5 (permalink)
mb333's Avatar
The gas light started flashing so I immediately went to that gas station and put some gas in. Could this have anything to do with the battery? Also if putting gas in fixes the problem, Will the check engine light automatically go off or do you have to have someone clear it off?
Old 05-09-2008, 03:57 AM   #6 (permalink)
ohlord's Avatar
Don't start a whole new thread everytime.
just reply to your original thread...........
So we will consider this the beginning.
The fuel lamp blinking is a pre check engine light warning to indicate a leak in the fuel emissions system .Has the check engine light gone off since you checked that the fuel cap is on correctly?
If not unscrew the fuel cap and gently pry out the gasket and flip it over and reinstall the cap.See if that clears the check engine light.
ohlord
Old 05-09-2008, 10:00 AM   #7 (permalink)
mb333's Avatar
Thank you for your reply's. I have taken off the gas cap and turned the rubber gasket around and the light is still on. The gas cap was wet when I took it off and somebody dropped the gas cap when getting gas yesterday. Are any of these factors?
Thank You-1997 E420
Old 05-09-2008, 11:17 AM   #8 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Thank You-1997 E420
Hey, mb333, please update your profile with your car and location info as that is useful information.
Also, please stop posting a new thread on this topic. All you do that way is add confusion and destroy the consistency of the thread. Go to your current post and add your information there. And you'll find my response to your above inquiry in that thread as well.
Take care and enjoy the ride,
Greg
Old 05-09-2008, 11:21 AM   #9 (permalink)
gregs210's Avatar
Thank You-1997 E420
Yes. You pretty clearly have a problem in the vent/recovery system. Dropping the cap isn't necessarily good or bad it all depends on how it hit, etc. But it shouldn't be wet. Check and clean the purge valve, pull the charcoal canister, let it all dry out (I would probably replace the gas cap as well as the charcoal canister, it's probably saturated, that and the purge valve are in the DIY stickies). After you do all that disconnect the battery and step on the brake for a half a minute to reboot the car, then when you start it back up you'll have to go through the resets (windows, ABS, radio) but that will also clear the codes and if everything is okay in the vent/evap system you'll be good to go.
Greg
ENGINE ELECTRONICS CHECK ENGINE LIGHT AND MESSAGE ping2day W210 E-Class 5 04-26-2007 11:21 PM
Check engine electronics, Check oil level.+ others bondale W210 E-Class 5 11-10-2006 01:02 AM
HELP: Check Engine, Engine Electronics ON az2md W210 E-Class 3 06-01-2005 08:25 PM
Check engine - electronics JohnR W210 E-Class 4 02-26-2004 07:05 PM
Check engine electronics msg mb-mopar_nut W210 E-Class 2 12-03-2003 09:45 AM
