Old 05-06-2008, 09:38 PM   #11 (permalink)
reyna7's Avatar
Vehicle: 2000 E430 Sport
Originally Posted by ohlord View Post
at
Harbor Freight Tools - Quality Tools at the Lowest Prices
r134a test gauge set.
ohlord
run the diagnostics first.
WOW
Thanks Ohlord!
reyna7 is offline   Reply With Quote
Old 05-07-2008, 10:03 AM   #12 (permalink)
Date registered: Feb 2006
Vehicle: 2001-W210-CAPRI METALIC BLUE-
Cool New codes
Hello Again;
I may have messed up the reset, what should the normal P! and P2 values be??
What a mess!!!
B
1=89
2=76
3=87
4=87
5=85
6=186
7=6
8=93
edc
227
231
234
235
416
422
241
And I don't know how to reset the edc's to get mcurrent values.
tried arrow buttons etc.
B
The finest example of automobile engineering in the world
Floats like a CADI
Stings like a BMR
Stingy as a Prius
and.... all Mercedes Benz.
MRBSMITH is offline   Reply With Quote
Old 05-09-2008, 10:01 AM   #13 (permalink)
Cool It Works
Thanks ohlord for the tip.
I could not find how to clear the error codes anywhere.
So I did as ol said, hold both Auto buttons while in the error code mode.
The EC light went right off and the system started right up.
It went to 11 bars and 39 at the coils. Just about perfect.
So net net what I did was force in a can of 134, then cleared the error codes.
That takes it out of EC Lock.
After the fact, I messed up the P1-2 but it all works.
THX Forum
Old 05-11-2008, 07:33 PM   #14 (permalink)
Date registered: Jun 2007
Vehicle: 1999 E300 Turbodiesel
Send a message via AIM to RRags
In reading about the P2 override setting someone suggested using a base 2 before adding the 16 value. Could someone please explain this further. Thanks, Rick
RRags is offline   Reply With Quote
Old 05-11-2008, 08:18 PM   #15 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
I'll try, RRag.
A decimal number has a binary (base 2) representation. In binary, each digit is a 0 or a 1.
1d = 1b
2d = 10b
3d = 11b
4d = 100b
16d = 10000
The fifth place (from the right) is the sixteen's place in a binary number. Now, these individual digits are commonly called "bits" which is a term invented by Claude Shannon. Each bit means something different to the climate computer.
Let's say that your P2 version is currently 144. In binary this is 10010000. Note that the sixteen's bit is set. Adding another sixteen, 144 + 16 = 160 which is 10100000. We've turned off the sixteen's bit by adding yet another 16. It was already set with the value 144.
By the way, the most convenient way (for me) to compute the binary representation of a number is using Windows Calculator. Select "View | Scientific" from the menu bar, enter a number in decimal and hit the "Bin" radio button.
Old 05-11-2008, 09:29 PM   #16 (permalink)
Matt, Thanks for the tutelage on the base 2 I guess I don't get the binary breakdown. I knew computers use series of 1's and 0's for encoding but would that it was Greek to me (I still remember a bit of my three yrs of classical Greek) but this is not clear to me now.
Anyway, I didn't screw up by adding 16 to the 136 as you replied in another post of mine about this same a/c issue. Where do I find the postings here for that blower motor regulator? Still haven't found anything about it. Thanks again, Rick
1998 mercedes 320, ml , a/c blows freezing cold air,then hot air bevleblanc W163 M-Class 7 08-25-2005 08:23 PM
SLK 230 Kompressor Intercooler: Air-to-Air or Air-to-Water?!? Please help! SilviaS14 R170 SLK Class 5 12-25-2003 12:23 AM
SLK 230 Intercooler-Water to Air or Air to Air?!? SilviaS14 R171 SLK Class 1 12-24-2003 09:23 AM
Tom, at parts.com, is "Air Intake, Adapter, Gasket" same as the air inlet tube? Andy R170 SLK Class 4 03-30-2002 03:22 AM
230K Stock Intercooler - air-to-air or water-to-air? Arnee R170 SLK Class 2 01-05-2001 02:23 PM
