Old 05-03-2008, 12:31 PM   #1 (permalink)
Date registered: Aug 2007
Vehicle: 1998 E320 4matic wagon
Wagon hatch lift struts possibly going out
one or both struts are making a squeeky noise and the door doesn't lift as easily as I remember. Does strut replacement require alot of trim removal? and anyone know if the struts are auto parts store generic or special order.
korbenz is offline   Reply With Quote
Old 05-03-2008, 01:00 PM   #2 (permalink)
ohlord's Avatar
Dealer
or aftermarket oem supplier like quote from autohausaz.com or try
RBrenton on mbworld.org w210 section
If I can remember long enough I know a guy who did his and I'm seeing him sunday so I will ask what it entails.
ohlord
Old 05-03-2008, 08:12 PM   #3 (permalink)
thanks
my hunch is some trim will need to be pulled, hoping that's not the case
Old 05-03-2008, 09:55 PM   #4 (permalink)
raymond-'s Avatar
Date registered: Jan 2004
struts wear out, eventually. mini shock absorbers. you can see if the strut has
a model # stamped on it and try to buy a generic one. truth is, I've never seen
an MB one up close so unknown how specific a brand/model. I have replaced on
a couple of trucks and because the access is so out in the open, they take less
than 5 mins total. hope it's relatively easy for you.
raymond-
47º34'N 122º18'W
raymond- is offline   Reply With Quote
Hatch Struts conbobway W124 E,CE,D,TD Class 0 03-27-2008 03:38 PM
anyone replaced gas lift struts on wagon hatchback? korbenz W210 E-Class 0 11-26-2007 02:06 PM
98 ML 320 Rear Hatch Struts KCML320 W163 M-Class 2 12-21-2005 01:59 PM
td back hatch struts solid gold W123 E,CE,D,CD,TD,TE Class 5 09-08-2005 05:38 PM
Replacing W124 wagon hatch struts Pretorien W124 E,CE,D,TD Class 2 07-03-2003 02:07 PM
