Old 04-30-2008, 02:08 PM   #1 (permalink)
twalton's Avatar
Date registered: Jan 2005
Vehicle: 2001 E430 4Matic 2005 S500
Xenon self-levelling
I just purchased a 2001 E430 4Matic that has Xenon headlights. I also have a 98 S500 with Xenon. When I turn on the headlights in the 500, they drop down and then raise back up and level off (self-levelling).
Question: is this supposed to happen in the E430 as well? I do not see any noticeable movement in the headlights upon switching them on. The light output and cutoff pattern are much better in the 500 also.
Just wondering if I have a problem or if these are operating as intended.
Thanks,
trey
twalton is offline   Reply With Quote
Old 04-30-2008, 03:16 PM   #2 (permalink)
Premium Member
acarter53's Avatar
Date registered: Dec 2006
Vehicle: 2001 E430 Sport in Desert Silver and 2002 C320 Sport Wagon in Arctic White
Premium Member
Send a message via Yahoo to acarter53
My last car was a BMW 740 and when i turned the lights on they would also adjust up and down. My E430 will only adjust if the the car is at a strange angle. Its very slight. I do notice movement in the light beam if I'm driving on a road with hills.
E430 Sport
2001 E430 in Desert Silver with Sport Package, COMAND, Xenon Lights, Rear Sunshade, Heated Seats. Added K40 Stealth Radar, 30% Tint, XM Radio! www.premierbasement.com
acarter53 is offline   Reply With Quote
Old 04-30-2008, 03:18 PM   #3 (permalink)
Diego97's Avatar
Date registered: Feb 2007
Vehicle: 1997 E420 Sport-2004 Land Rover Discovery-2004 Mercedes Sprinter 3500-2001 Roadstar-1969 Chevy C10
fwiw, my 97 E420 had xenon self leveling lights, until i swapped them out for HD bi-xenons from zam2000 and now i piss everyone off that approaches me, but i digress... mine did not move down when turned on but then again yours is 1 year newer and 1 model up so i'm not sure... sorry for wasting your time
Diego97 is offline   Reply With Quote
Old 04-30-2008, 04:04 PM   #4 (permalink)
Musikmann's Avatar
I have a 2001 E320 with the Lighting Package (xenons and headlight washers) and as far as I know, these are not self-leveling.
Old 04-30-2008, 07:31 PM   #5 (permalink)
Franasia's Avatar
Vehicle: 2000 E320S4 210.282
Yes they are. Xenon headlamps are self leveling on W210 and mandatory to have washers as well, as per ECE regulations.
It seems to me that Xenons with projectors have this up and down movement when first turned on.
Cheers
“Design embodies the values of a company. Even if there were no star, the car must always be recognizable as a Mercedes-Benz.” Peter Pfeiffer, Daimler AG
Franasia is offline   Reply With Quote
Old 04-30-2008, 09:26 PM   #6 (permalink)
Musikmann's Avatar
Franasia,
If you are correct I apologise to the OP for the mis-information. When I engage my headlights, there is a temporary color change in the lights (xenons firing up), but I have never noticed any up/down movement of the beams.
What does ECE stand for please?
Old 04-30-2008, 10:56 PM   #7 (permalink)
raymond-'s Avatar
Date registered: Jan 2004
(UN)ECE
raymond-
47º34'N 122º18'W
raymond- is offline   Reply With Quote
Old 05-01-2008, 12:59 AM   #8 (permalink)
Date registered: Aug 2006
The leveling of the lights at startup is not very pronounced as with other manufacturers. The lights are auto self leveling. If you drive at any gradient, uphill or downhill, they will adjust within a few seconds. If they do not adjust, then you most likely have a problem. The internal leveling cogs are made of plastic and they will eventually wear out and malfunction.
alamg55 is offline   Reply With Quote
Old 05-01-2008, 07:46 AM   #9 (permalink)
Date registered: Aug 2007
Vehicle: W210 1998 E430
All cars made in Germany equipped with factory xenon lights must have both self-levelling and washers built-in by law, as previously stated on this thread.
This is to ensure that the high-output xenons do not blind other drivers. The self-levelling to keep the beams focused and the washers to ensure that dirt, etc. does not cause the beam to become scattered, potentially blinding other drivers.
Newer cars perform the level check at startup and level the lights. The W210 chassis has sensors mounted on the underside on the suspension. The lights do not level at startup, rather if the sensors detect that the car is not level, motors on the lights will adjust them to the correct level very quickly.
The color change you are seeing at startup with xenons is pretty cool. It is the result of different gases vaporizing at different times. To produce the final light 'color', a plasma discharge arc is created by the vaporization of xenon first, then mercury then halide salts.
Benzboy210 is offline   Reply With Quote
Old 05-01-2008, 09:35 AM   #10 (permalink)
ozcan's Avatar
Date registered: May 2003
Vehicle: 00 ML430 & 01 E430 4matic Both Silver+Black
My current E430 2001 and E320 2000 (which I sold recently) both had factory Xenon lights. I never noticed any leveling on the E320. But my E430 4matic occasionally does adjustment depending on the road conditions. As Benzboy210 wrote;
Originally Posted by Benzboy210 View Post
All cars made in Germany equipped with factory xenon lights must have both self-leveling and washers built-in by law, as previously stated on this thread.
My previous E320 must have had leveling problem.
E430 2001 4Matic Silver All factory options + 30% tint
"xenon, parktronic, navigation, voice recognition, rain sensor, multicontour seats, vantilated seats, rear curtain ect"
OPTION LIST STICKER
ML430 2000 Silver MODS: Bi-Xenon, Chrome Grill
Previous cars: E320 2000 Nav, xenon, voice - 300E 1991 - 190E 1985 - 190D 1984 - 200SE 1976
MY SIMPLE E430 & ML430 WEB
ozcan is offline   Reply With Quote
Are all estates self levelling. james007 W202 C-Class 0 02-11-2007 11:25 AM
Auto levelling system for Bi-Xenon. How does it work ? miroj W203 C-Class 3 05-17-2005 06:56 AM
Bi-xenon headlights auto levelling? Bora20 W163 M-Class 1 09-29-2002 11:54 AM
Self levelling?? Guest (MBNZ) W123 E,CE,D,CD,TD,TE Class 1 01-04-2002 01:42 PM
Self levelling?? Guest (MBNZ) W123 E,CE,D,CD,TD,TE Class 2 11-05-2001 12:25 PM
