you have my plug boot tool, the must have 17mm boot remover?
sold for $28 delivered
if you do and if you have a few different extensions a socket and a set of torx bits you can be done in under 3 hours maybe even two hours even if you have never done plugs in your life.
NGK 7090 about $2.75 each times 12 pop off the engine cover,remove the air box cover and the maf and tubing,follow the diy and the extra tips I give you with the tool and wiz through the job.
no anti seize,clean the maf with crc brand maf cleaner while you have it out.
have fun ohlord
anti seize on the new plugs they are plated with a non seize plate and you will not get a correct torque reading if you need to use a torque wrench v.s. the old school method.If you have done plugs before with the 17mm boot tool it takes under an hour.
i use old school.... once while removing some NGKs from my infiniti i was in fear that i was going to strip the threads out of the hole bcause whoever installed the plugs did not use anti sieze.
james
and bunkum
You have nickel plated threads in a 100% aluminum head.Putting anti seize on affects nothing more then throwing off properly torquing the plugs and if a single smidge gets on the electrode it will ruin a perfectly good plug causing a misfire which if ignored can take out a perfectly good cat converter.Now while most members won't ignore a misfire cel light I have seen people ignore them for two years and wonder why the car started running like crap and that they have 2 bad cats
no anti seize
ohlord
