Old 03-20-2008, 08:39 PM   #1 (permalink)
Date registered: Mar 2008
Vehicle: 2001 E320 Wagon
DId my DIY oil change - looking for oil extractor
Just completed my oil change. Boy the car sits very low and the Rhino ramps that I have do not work well.
I am now looking for an oil extractor. I know that the topsider is popular here but I am looking for a unit where you can see the amount of oil extracted.
What do you guys think of Pela?
An issue with oil extractors is the diameter of the dipstick tube. Anyone know what the diameter is off hand? How about the ATF fill tube?
Thanks
yumling is offline   Reply With Quote
Old 03-20-2008, 09:12 PM   #2 (permalink)
E-Klasse's Avatar
Vehicle: E320, SLK320, MKV Jetta TDI, Mini Cooper S
I use the Topsider. I got it at a boating supply place. It works great if I drive the car for about 30 minutes just before pumping the oil out. The 1/4 inch tube fits right down the dip stick spout and gets to the bottom of the oil pan. With the oil warm, it flows right out and save you from pumping up the vacuum in the canister a lot of times. I have seen more upright suction type oil extractors but they are made out of plastic and cost more than the metal topsider.
I assume no liability for any incidental, consequential or other liability from the use of this information. All risks and damages, incidental or otherwise, arising from the use or misuse of the information contained herein are entirely the responsibility of the user. Although careful precaution has been taken in the preparation of this information, I assume no responsibility for omissions or errors.
E-Klasse is offline   Reply With Quote
Old 03-20-2008, 09:39 PM   #3 (permalink)
Kajtek1's Avatar
Vehicle: E300DT/320cdi ML320/55
MityVac here. I use it on hot oil without the problem. Like transparent tank, that lets me see how much oil is in it. The biggest tube (I think it is about 3/8" seals in the dipstick tube funnel allowing for clean suction without unnecessary restrictions.
Kajtek1 is offline   Reply With Quote
DIY : Oil Change hangon W163 M-Class 44 09-19-2008 03:29 PM
Poll: mileage between oil change / brand of oil / DIY or dealer ?? Thanks! Rohf (Seattle) R170 SLK Class 27 08-05-2008 08:58 PM
DIY oil change Neb W202 C-Class 28 06-12-2008 06:18 PM
SLK55 DIY Oil Change shark22 R171 SLK Class 1 03-13-2008 10:14 AM
