» Site Navigation
» Other Sites
Old 03-17-2008, 07:47 PM   #1 (permalink)
nsupra's Avatar
Date registered: Nov 2006
Advice on tires / suspension.
Alright so i need some advice before i begin my next mod. I have a 430 with e55 amg monoblock take off's. I am due for new tires by next month or so. Currently i am running 245/40/18 in the front and 275/35/18 in the rear(stock for those wheels). Every time i am going at least 40 mph or faster and there is a huge dip in the road that will compress the suspension one of the front tires will hit the fender. My question is would going to 235/40/18 and 265/35/18 fix that problem or no? The next mod that i want to do shortly after i change the tires i want to install bilstein sport shocks and h&r springs. Of course that is going to drop the car. So i guess my main question is will 235/40/18 and 265/35/18 clear the car or no still to close. Also i noticed that my rear tires have negative camber to them. Is it a must to install a camber kit? Any adivce is greatly appreciated thank you.
nsupra is offline   Reply With Quote
Old 03-17-2008, 08:16 PM   #2 (permalink)
Musikmann's Avatar
You are on the "right" forum for your car, but if you don't get an answer quickly, scroll down the the Technical Forums and you will see one for tires, suspension, etc.
Old 03-17-2008, 08:36 PM   #3 (permalink)
nsupra's Avatar
thank you
Old 03-17-2008, 08:52 PM   #4 (permalink)
Premium Member
acarter53's Avatar
Date registered: Dec 2006
Vehicle: 2001 E430 Sport in Desert Silver and 2002 C320 Sport Wagon in Arctic White
Premium Member
Send a message via Yahoo to acarter53
Yes it will. I just took my AMG Monos off and that is the tire size that I had on. The car never ever rubbed. Tire Rack strongly reccomended that I put the 235's up front and the 265's in the rear.
E430 Sport
2001 E430 in Desert Silver with Sport Package, COMAND, Xenon Lights, Rear Sunshade, Heated Seats. Added K40 Stealth Radar, 30% Tint, XM Radio! www.premierbasement.com
acarter53 is offline   Reply With Quote
Old 03-17-2008, 09:06 PM   #5 (permalink)
nsupra's Avatar
Originally Posted by acarter53 View Post
Yes it will. I just took my AMG Monos off and that is the tire size that I had on. The car never ever rubbed. Tire Rack strongly recommended that I put the 235's up front and the 265's in the rear.
That is good to hear thanks! I wonder if any handling or feel of the car would be noticeably lost with the slight smaller tire.
Old 03-17-2008, 09:12 PM   #6 (permalink)
Premium Member
acarter53's Avatar
Premium Member
The ride may improve slightly, but the handling will not suffer at all. The difference is very minimal. Watch the fenders when you lower the car. and get a good alignment.
Old 03-17-2008, 09:32 PM   #7 (permalink)
nsupra's Avatar
Nice thats awesome to hear. yeah most definite will get a good alignment.
Old 03-17-2008, 09:50 PM   #8 (permalink)
raymond-'s Avatar
Date registered: Jan 2004
one caveat: there is a slim chance that, given your tire selection (not the size,
but the model) you may still get fender lip rub even with 235/40. why? because
not all tires of the same size, have the same profile. those with nice, tall shoulder
may still (again, not unheard of) touch the lip upon hard compression.
you have a narrow offset up front with the E55 rims. by changing from 245mm
to 235, this only results in 5mm less from the lip. you should gauge the degree
of rubbing (observe where on tire the scrape is occuring) and estimate if the
rubber was 5mm less, would it still rub?
then, you're also proposing offsetting this 'savings' by lowering, thus robbing
what you may have just tried to resolve through smaller tire.
acarter's tire (235) didn't rub, but that's not a guarantee that your's won't.
why? because not all suspensions are the same. different coil/spring rates,
different shock dampening rates, etc etc all factor into this to skew the
evaluation. assessment of the final outcome must take all these specs into
consideration.
by any chance the tire rubbing is the left front?
raymond-
47º34'N 122º18'W
raymond- is offline   Reply With Quote
Old 03-18-2008, 02:56 AM   #9 (permalink)
Date registered: Jun 2007
HAD A 97 E420 WITH 245/40/18 MICH PILOT SPORTS ALL THE WAY AROUND WITH 31 ET RUBBED IN LEFT FR ONLY ON HARD COMPRESSION.
benzzn55 is offline   Reply With Quote
Old 03-18-2008, 08:38 AM   #10 (permalink)
nsupra's Avatar
consideration.
Thank you for your input. Currently the tires that are being used are michelin pilot sports and i bought the rims with these tires. I want to get another summer performance tire since i only use these wheels for the summer anyway. I was thinking of getting new Goodyear eagle f1 gsd3's or there newest tire the asymmetric ( The biggest size they come in are 265). Both current tires have done there share of rubbing but i think i would say the passenger front tire rubs more. I dont know if it has to do with just the way the dips are in the road.The very very outer edge rubs Yeah after the tires rub a piece of spliced rubber is dangling from the tire ( but not so much anymore think it has happened to much now that the front tires dont splice any more rubber) By the way why do you ask only if the front left tire rubs?
Anyway i am guessing the smartest thing to do before i even drop the car with suspension would be to roll the fenders. Any idea how much this costs?
Need suspension advice for a 2.6 Funky Mad W201 190E, D-Class 3 11-20-2007 08:00 PM
new suspension/ Help Advice jimmypop W126 S,SE,SEC,SEL,SD,SDL Class 0 05-03-2007 08:51 PM
Suspension Advice Please andy.cowman W201 190E, D-Class 11 09-23-2006 11:23 AM
Suspension Upgrade - Need Advice Cabrio R170 SLK Class 3 05-09-2004 09:48 AM
suspension advice help Guest (MBNZ) The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 11-11-2001 09:50 PM
