Old 03-17-2008, 02:40 PM   #1 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Strange little radio issue...
Hey, folks.
So I went out to run an errand. Hit the remote, door unlocks as usual.
Open the door, the cluster lights up (as usual).
However, the radio also comes on.
I stopped and stood there with the deer-in-the-headlights look, glancing at the key in my hand and the dash. "Yes," my brain registers, "the radio is on and the key is in your hand."
I'm used to the radio playing when I turn the car off, at least until I remove the key from the ignition. "But this," I say to myself, "is new."
Unfortunately I had the radio off at my destination, so when I got back in the car, I hit the radio button -- key in my hand -- and the radio came on. (No, it wasn't playing Ghost in the Machine.)
One more errand, left the radio on. Unlocked the car, cluster lit up, but no radio.
I'm going to guess it's a transient, if it recurs I'll do the reboot.
Just curious if any of my peeps have experienced anything like it.
Take care and enjoy the ride,
Greg
Meister Eckhart
Old 03-18-2008, 04:03 PM   #2 (permalink)
citruspilot's Avatar
Date registered: Dec 2006
Vehicle: 97 E420, Boeing-717, 03 Explorer, 03 Honda Civic, 1988 Glastron Carlson CVX-23 (boat)
Greg, I just went out to my garage and opened up my 97 E420 sat in the drivers seat and hit the radio button, key in pocket. The radio comes on. Its like the "rest" mode on the cabin ventilation fan. I can hit the rest button, with key in pocket, and the fan will come on. I guess thats so you can get air movement while you listen to the radio, key in pocket.
Jeff
citruspilot is offline   Reply With Quote
Old 03-18-2008, 04:38 PM   #3 (permalink)
gregs210's Avatar
Hi, Jeff. Thanks for testing yours. I have also tried mine again and it functions as you describe. So now I am just curious as to why it came on the one time as a result of my simply opening the door.
Maybe 'tis but a precursor of something completely unrelated. For sure I an not rolling down my rear windows!
Greg
Old 03-18-2008, 04:48 PM   #4 (permalink)
Musikmann's Avatar
I just tried mine too. I could turn the radio on and get the rest mode to engage without having the key in the ignition. Like you Greg, if I have the radio playing it stays on down to the removal position but it stops (with a momentary delay) after removing the key.
Old 03-18-2008, 04:48 PM   #5 (permalink)
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
Greg you need to refill those medications, send MM a Pm he might give you a discount
JOE55 is offline   Reply With Quote
Old 03-18-2008, 05:30 PM   #6 (permalink)
Musikmann's Avatar
I certainly would if I was a pharmacist Joe! In fact, I would also have found some way to send you samples of that new medication for OCD
On a more serious note, I work for a company in the woundcare field so you were close; just no cigar for you today...
Old 03-18-2008, 05:40 PM   #7 (permalink)
Wow. A drug connection! My wife could use some free samples of Ambien...................................my wife.................yes, my wife........
Jeff
PS: Thats not my dog, thats me..................
And no, I dont need Viagra..................
Old 03-18-2008, 06:16 PM   #8 (permalink)
gregs210's Avatar
I tried, but he didn't have the proper pdf decoder.
Sadly or not, it wasn't drugs. That's why it took a minute to register. (Actually, since then I've been considering Matt L's comment on the K40 relay...)
Strange Issue Electronics TNTRower W210 E-Class 3 11-30-2007 02:38 PM
Strange Stereo/Amp issue '91 300CE W124 E,CE,D,TD Class 1 09-03-2006 08:04 AM
Radio Harness issue, Tuner issue DamianC R170 SLK Class 1 08-28-2006 07:46 PM
Strange Hot Start Issue . . . Captain Spalding G-Class 11 06-06-2005 06:08 AM
strange cruise control issue snik W140 S-Class 7 03-06-2005 06:07 PM
