Old 03-17-2008, 09:52 AM   #1 (permalink)
citruspilot's Avatar
Date registered: Dec 2006
Vehicle: 97 E420, Boeing-717, 03 Explorer, 03 Honda Civic, 1988 Glastron Carlson CVX-23 (boat)
E420 Power Steering Pump............
1997 E420. Hey all, I have a small leak coming from my power steering pump. Most likely from the front seal behind the pulley. I clean it off periodically using some Purple Power and high pressure water. But within a few drives the fluid starts flinging off the pulley and makes a mess. If I drive a long distance it will lose enough to start dripping from under the radiator. Not much but a few drops. The car has never leaked before and so now its getting to be an issue. Anybody here purchased a rebuild kit? I can rebuild it I am sure only need to know where to get the kit cheaply. Thanks in advance.
Jeff
citruspilot is offline   Reply With Quote
Old 03-17-2008, 10:15 AM   #2 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Jeff
Hey, Jeff.
I have to say I've never seen a rebuild kit for a MB. Without a good press setup I'm not sure how you'd disassemble and reassemble it but that's a different issue. When it first started you might have been able to soften up the seal with one of the additives on the market but if it's leaking that badly the seal is probably cracked (or the bearing is so worn it's allowing the shaft to orbit slightly, opening the edges of the seal). It's an expensive part ($260 or so online) but I'm going to bet you'll end up having to replace it.
If it's not your primary driver you might be able to pull the pump and remove the pulley and then carefully extract the seal and locate a new one; there is some level of standardization in things like that. Of course that's not going to help if it's the bearing, but if you get it out you might also be able to find the bearing.
Sorry I couldn't be of any better help.
Take care and enjoy the ride,
Greg
Meister Eckhart
Old 03-17-2008, 11:19 AM   #3 (permalink)
E-Class Owner's Avatar
Vehicle: 1997 Mercedes Benz E420
If he can...
extract the seal and [if necessary] the bearing, he can go to a bearing specialty shop, similar to "Bearing Engineering" here in the Bay Area, and they will fix him up.
The input shaft should be checked for play as Greg suggests before investing a lot of time on a small scale "rebuild". Daimler Benz [and not Daimler Chrysler] used to make rebuild kits for PS pumps "back in the day"... a call to the dealer might turn something up... one never knows.
Good luck,
JR
E-Class Owner is offline   Reply With Quote
Old 03-19-2008, 07:57 PM   #4 (permalink)
Date registered: Mar 2007
Vehicle: 1997 E420
I just had the same problem. I took off the pulley and removed the front of the pump by removing the 5 or 6 bolts. You can then remove the clip holding the shaft in place. Once you pull the shaft out you will see the seal causing the leak. This seal should pop out with a little preasure.
Be careful ordering the rebuild kits. They don't seem to have this seal size included (33.33x15x8 I believe) for the 97 E420. I had to go to the dealership and the correct seal size was in a kit for a different model. The kit is Mercedes Part number A 000 460 47 80.
The recommendation from Mercedes is to replace the entire pump. So far so good with replacing the seal only.
Good luck.
todd557 is offline   Reply With Quote
Old 03-19-2008, 08:06 PM   #5 (permalink)
ohlord's Avatar
Totally
wrong.The recommendation from Mercedes is to replace the engine assembly including all ancillary components
ohlord
ohlord is online now   Reply With Quote
Old 03-19-2008, 08:14 PM   #6 (permalink)
Vehicle: 1997 E420
Got to love 'em
Old 03-20-2008, 06:15 AM   #7 (permalink)
todd557, boy that sounds way too easy. So, you pull the belt, remove the pulley off the front of the P/S pump, remove the front of the pump, then remove a clip and the seal is right there? Man, if thats the case I'll do it this weekend............
Thanks for the tip and correct part #'s....................
PS: how much fluid do you lose doing this? Does the holding tank drain to the seal level?
Jeff
Old 03-20-2008, 07:37 PM   #8 (permalink)
Vehicle: 1997 E420
You remove the front hose first and drain the fluid from the resevoir into a large cup. The hardest part was removing the clip that prevents the shaft from coming out. I popped it off with two flat head screwdrivers.
Just go slow and have some patience. The last thing you want to do is scratch the metal and inner workings.
You will have no problem. Lets us know how it goes.
Old 03-21-2008, 08:59 AM   #9 (permalink)
Date registered: Jan 2007
wut a coincidence, i got the same car, same yr, same model, guess wut same problem rite now, my dad who is the lead tech at the local MB dealership told me i would have to replace the hold thing, trust me my dad is all about going the cheap way if there is one, so let me know if that seal fix works. i love to prove him wrong sometimes. i was refilling it like once a week until i bought lucas power steering leak sealer, its been about three weeks now, so i guess its a fix for rite now until i can save for that $400 pump.
ismiley is offline   Reply With Quote
Old 03-21-2008, 09:14 AM   #10 (permalink)
Vehicle: 1997 E420
Jeff....one more tip.....loosen the three pulley bolts prior to removing the belt. You might find the belt holds the pulley snug enough for you to loosen them.
It has been 3-4 weeks and the new seal has solved the problem.
Squeaky, Creaky Power Steering E420 redheadeight W124 E,CE,D,TD Class 7 01-14-2008 04:56 PM
power steering pump, rebuild kit or used pump Tye W123 E,CE,D,CD,TD,TE Class 5 08-10-2007 09:27 PM
92 400E Power steering pump and water pump, need advice kanio W124 E,CE,D,TD Class 5 03-19-2007 06:58 PM
power steering pump thevj W163 M-Class 2 12-18-2006 11:00 PM
Power steering box and power steering pump thoth_9 W123 E,CE,D,CD,TD,TE Class 5 08-21-2005 09:52 PM
