Old 03-13-2008, 01:10 PM   #1 (permalink)
Date registered: Jun 2007
Vehicle: 2002 E320 4MATIC Special Edition, Black
Question Hardwiring a radar detector - Anyone?
I'm really sick of the power cord drapping down the dashj...has anyone ever hardwired a power source for a radar detector and how did you go about it?
I found this from another source, but I'm curious if/where anyone has tapped into for a power source.
Cheap way to hardwire your Escort 8500 X50 - Car Audio, Video & Security - NASIOC
2 random extras
1 key turn (no hold) for ignition is sweet! Thanks for whomever brought that thread to life.
Daniel Stern lights rock!
ajent420 is offline   Reply With Quote
Old 03-13-2008, 01:52 PM   #2 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
Getting the wire from under the dash to above it is the hard part. On my car, there is an air passage between the cabin and the underhood fusebox, and it's fairly easy to fish a wire through.
Old 03-13-2008, 05:15 PM   #3 (permalink)
Date registered: Dec 2002
Vehicle: 92 500SEL -01 E320T
The visor mirror has power with the ignition on
Peter Guenther is offline   Reply With Quote
Old 03-13-2008, 05:21 PM   #4 (permalink)
Premium Member
acarter53's Avatar
Date registered: Dec 2006
Vehicle: 2001 E430 Sport in Desert Silver and 2002 C320 Sport Wagon in Arctic White
Premium Member
Send a message via Yahoo to acarter53
Get the K40
I have the K40 Radar detector installed in my car. The receive is mounted under the front bumper and the LED's are built into my instrument cluster. This is the best way to go.
E430 Sport
2001 E430 in Desert Silver with Sport Package, COMAND, Xenon Lights, Rear Sunshade, Heated Seats. Added K40 Stealth Radar, 30% Tint, XM Radio! www.premierbasement.com
acarter53 is offline   Reply With Quote
Old 03-13-2008, 08:29 PM   #5 (permalink)
Date registered: Jul 2007
Vehicle: 2008 GL320CDI, 1999 E320 Wagon 4Matic
I went to my local car stereo installer shop and he hard wired my escort with the cord coming through the dash at the center of the base of the windshield for $40, he also installed an XM commander radio in the ashtray
dpallone is offline   Reply With Quote
Old 03-13-2008, 08:33 PM   #6 (permalink)
But would you let them do that to your wagon?
I like acarter's idea. In fact, there are several dead sockets in my cluster, which are the perfect size for a small grommet and an LED. I put a lamp to monitor my auxiliary fan there, but you could use them for anything. If you do, get the brightest LED you can buy, because you'll need it in the daytime.
Old 03-14-2008, 08:22 AM   #7 (permalink)
A1EK's Avatar
Date registered: Sep 2005
Vehicle: W208 CLK230 Kompressor 2000 year, Brabus Monoblock VI, 15mm spacers, Eibach Pro Kit, Flat emblem
Hi, When I had my W210 I found a really easy way of hard wiring my radar detector. I have it placed in the middle of the dash at the bottom of the window, as you will find that there is a small gap a few inches ling between the air vents. My radar was 12V which meant that you could get a power soource from anywhere.
First I took the tray off under the sterring wheel, there are a few phillips screws to undo and clips thats all. Once removed either with a volt meter or known 12V source connect a the flexible cigerete cable to it by removing the plug, with the negative going to any chasis point. Then get a coat hanger tape the end of the wire to it and push it under the dash to the central area of the dash where you want to mount the radar.
Second option if you cant find a 12V source thenuse the existing cigerete socket but get the wire under the ashtray to the rear of the dash and feed the wire through to the radar that way.
Good Luck
A1EK is offline   Reply With Quote
Old 03-14-2008, 08:31 PM   #8 (permalink)
johnny's E320's Avatar
Date registered: Jan 2008
Vehicle: E320 (W210)
A radar detector should be mounted as high on the windshield as possible, preferably flush with the roof of the car. Any other mounting is a waste of time, money and dash space. There is only one exception: many late-model cars windshields have auto-dimming/heating elements which may block radar signals, a catastrophic drawback for detector mounting. (Luckily, manufacturers like Mercedes often designate a specific location just for detector mounting, and it s no coincidence that it s high up, right next to the rearview mirror.)
Johnny : Chico, CA USA : 1998 Mercedes E320 : 2003 Honda ST1300
johnny's E320 is offline   Reply With Quote
Old 03-16-2008, 07:54 PM   #9 (permalink)
Premium Member
acarter53's Avatar
Premium Member
Thumbs up K40 In Dash Pic
Here is a pic of my K40 that has the LED's mounted in the cluster. The green light at the bottom right is the Highway mode and is switched to yellow for City mode. The Red light is the warning. I also have the audible alarm mounted on the driver side air vent.
Old 03-17-2008, 02:08 PM   #10 (permalink)
Premium Member
acarter53's Avatar
Premium Member
Question
Johnny,
Whats up with the feet thing???
Radar detector skiflyer Audio & Telematics Forum 16 09-19-2007 12:40 PM
radar detector hardwiring ... deyainrdy4ds W208 CLK Class 0 08-10-2007 04:00 PM
RADAR DETECTOR DEATHERAGE R170 SLK Class 37 06-24-2004 02:35 AM
RADAR DETECTOR Chucky300 W220 S-Class 14 12-25-2003 05:45 PM
What Radar Detector should I get... amginfo R170 SLK Class 4 06-15-2001 12:49 PM
