» Site Navigation
» Other Sites
Old 03-11-2008, 10:00 PM   #1 (permalink)
Date registered: Mar 2008
Post Timing Chain or Timing Belt
Hey all, this is my first post!
Does my 1999 E430 Sport have a timing chain or timing belt?
Thanks in advance
innaadrian2007 is offline   Reply With Quote
Old 03-11-2008, 10:04 PM   #2 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
You have a chain. I don't think there is a single automotive M-B engine with a timing belt. I doubt that any of their engines have timing belts.
Old 03-11-2008, 10:32 PM   #3 (permalink)
Date registered: Dec 2006
Vehicle: 1997 E320, 1997 S320
like always, matt is right. it is a chain and there is no service interval on the chain as far as i know.
tirona is offline   Reply With Quote
Old 03-12-2008, 06:53 PM   #4 (permalink)
ohlord's Avatar
Vehicle: 99 e320 wagon,bmw,vw,mgb,mg midget,subaru wagon
96-97
M104 motors you inspect the chain for stretch when you replace the leaking head gasket or timing chain cover which will usually precede the head gasket failure so you might as well do it at the same time.the m104 only has a single chain prone to stretching.
His m113 engine if properly maintained the double roller chains and silent, rubber-coated sprockets will last into long life.Same with the M112
ohlord
E55 timing belt or chain? SarahV W210 E50 AMG, E55 AMG 6 02-29-2008 09:43 PM
230E timing belt or timing chain? DieselKraut22 W123 E,CE,D,CD,TD,TE Class 19 06-20-2007 05:26 PM
Timing Belt or Chain dimon1980 W163 M-Class 2 10-09-2006 09:49 PM
Timing Chain or Timing Belt on 230 Kompressor ? Bal W208 CLK Class 0 11-21-2005 01:08 PM
Timing belt/chain change?? w140benz W140 S-Class 5 09-10-2003 01:02 PM
