Old 03-11-2008, 11:13 AM   #1 (permalink)
Date registered: Mar 2008
Vehicle: 2000 E430
00 E430 BAS/ESP/ABS malfunction
ABS System malfunction last night. This morning I got 3 malfunctions - BAS, ESP, and ABS. Any suggestions where to start?
GregSoDak is offline   Reply With Quote
Old 03-11-2008, 12:40 PM   #2 (permalink)
KADE's Avatar
Date registered: Jan 2006
Vehicle: E-320/ 2000
Do a search on brake switch replaced, and check the DIY= http://www.benzworld.org/forums/w210...lly-fixed.html if you want to DIY, pretty easy fix, part is $20 or so from dealer.
KADE is offline   Reply With Quote
Old 03-11-2008, 01:40 PM   #3 (permalink)
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
and check your car battery.
JOE55 is offline   Reply With Quote
Old 03-11-2008, 02:07 PM   #4 (permalink)
KADE's Avatar
Thanks JOE55 forgot about that, that can also cause the bleeping light malfunction
ESP-ABS-BAS Malfunction help please moaad001 W210 E-Class 11 09-26-2007 12:33 PM
ESP, BAS & ABS MALFUNCTION tnsr35 R171 SLK Class 11 09-01-2007 11:35 AM
bas/esp malfunction indicator lamp steven t lee R170 SLK Class 1 09-01-2007 12:22 AM
BAS ABS ESP malfunction after tightening loose steering column sdjumin W210 E-Class 0 10-15-2006 06:43 PM
HELP ABS, BAS, ESP Malfunction Detected DGW203 W203 C-Class 6 04-28-2006 09:13 AM
