» Site Navigation
» Other Sites
Old 03-09-2008, 07:17 PM   #21 (permalink)
rocketcaddy's Avatar
Date registered: Dec 2007
Talking 04 CLK 17"s on my 96 E320
I picked up a set of the five spoke 2004 CLK wheels with tires really cheap and put them on my E this weekend. Painted the calipers red and man do they look great. Really updated the look of the car. They have 225/45 front and 245/45 rear with no issues. They look like they came on the car.
rocketcaddy is offline   Reply With Quote
Old 03-09-2008, 07:48 PM   #22 (permalink)
larces's Avatar
Date registered: Feb 2008
Vehicle: w210 1999 E320 black
Send a message via MSN to larces
guys on my e320 99 i have the w211 rims the mb dealer sell me the rims and looks fantastic i will take a picture and posted asap but in my opinion the car look better whit open rims that the oem rims that are close
LOU
larces is offline   Reply With Quote
Old 03-09-2008, 07:56 PM   #23 (permalink)
ohlord's Avatar
Vehicle: 99 e320 wagon,bmw,vw,mgb,mg midget,subaru wagon
rocketcaddy
No issues other than the fact you have tires on the rear that are 7/10 of an inch taller and spin about 25 plus fewer revs per mile. Profile is a proportion of tire width 45% of 245 is a taller tire.Hope it does not affect the abs or the cruise control.
ohlord
A 255 /40 on the rear would be a no issue tire
Old 03-10-2008, 02:06 PM   #24 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
This post is useless without pictures.
Please post some here or in the sticky for this forum. THANKS!
Take care and enjoy the ride,
Greg
Old 03-10-2008, 09:23 PM   #25 (permalink)
raymond-'s Avatar
Date registered: Jan 2004
L-
I hope you got new lug bolts to go with those rims. The 211 rims use different
diameter bolt, as well as ball seat radius compared to your 210 wheels. If you
are still using the 210 bolts on your 211 wheels, the fitment will be poor.
raymond-
47º34'N 122º18'W
raymond- is offline   Reply With Quote
Old 03-10-2008, 10:36 PM   #26 (permalink)
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
JOE55 is offline   Reply With Quote
Old 03-11-2008, 03:58 PM   #27 (permalink)
96 E320 with clk rims
Sorry guys, I've been a little distracted.
1.) I did get the lugs that were on the CLK wheels originally.
2.)Not sure about the 245 vs. 255 but they came with fairly new tires and I will replace them ith 255's when the time comes. I haven't noticed any issues thus far.
3.) Pictures.
Old 03-11-2008, 04:42 PM   #28 (permalink)
ohlord's Avatar
Look
nice
now all you need to do is drop it a few
cool
Old 03-11-2008, 05:33 PM   #29 (permalink)
gregs210's Avatar
Originally Posted by ohlord View Post
nice
cool
Well, that and get the correct-size tire on the front to close up that gap some more.
Rocketcaddy, they do look good but since they're staggered wheels the conventional wisdom is you'll have to stay that way (not recommended to put the same size tire on different width rims as it *can* adversely affect handling). Your stock equiv size (and the largest you can run on the front without rubbing suspension parts) is 235/45-17, you can run the 245/45-17 in the back just fine. Your speedo will read slow, just back off a bit.
Greg
Old 03-12-2008, 07:19 AM   #30 (permalink)
Date registered: Aug 2007
Vehicle: W210 1998 E430
Originally Posted by raymond- View Post
L-
Raymond - this picture illustrates the main question well. I agree that the custom bolts will create a good fit, with the 14mm ball seat and the 12mm diameter threaded shaft.
What I am wondering is - with the custom lug bolts, will that wider ball seat direct more force upon the 12mm shaft than it can take, as opposed to the wider 14mm shaft found on the W211 bolts?
That is the weak point, I think. When they made the 14mm ball seat, they also made a wider diameter shaft. So when you take a custom bolt with a wide, 14mm ball seat and mate it to a 12mm diameter shaft, will that shaft be able to support the forces exerted upon it at the point where the curved ball seat meets the threaded shaft?
Benzboy210 is online now   Reply With Quote
FINAL DECISION TIME - RIMS! Synthetic R170 SLK Class 15 11-15-2007 04:16 PM
Will W211 rims fit on W210? farsal W210 E-Class 16 06-23-2007 09:18 PM
fitting W210 (12mm lug) rims on W211 (14mm lug)? schlol The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 05-04-2007 02:48 AM
Correct lug bolt for W211 stock rims for W210 application Raylee177 W210 E-Class 10 03-01-2006 09:58 AM
okay guys...i know we've been through this a million times..but i need a final consensus (more) confused W208 CLK Class 2 10-05-2001 07:51 AM
