Old 03-08-2008, 07:29 AM   #11 (permalink)
raymond-'s Avatar
Date registered: Jan 2004
Originally Posted by RoadsideDude View Post
hello, greetings from south carolina; i work at a dealership and i have never been able to fit a set off 211 16 or 17 inch wheels on a 210. the last time we tried a set, a few months back, the wheels didnt fit on the hub correctly on the front. i dont remember exactly what the problem was, but know now that 211 wheels wont fit on a 210. if im wrong someone please tell me, but i dont think i am, and that is the reason we have ne ver put 211 wheels on a 210. 210 wheels will fit on a 124, with slight rubbing at the rear wheel well, with bigger than a 225/60/16. i dont want to mislead you, but im pretty sure im right. im at roadsidedude@hotmail.com if you have any other questions. good luck with your venture, i think the 17 inch wheels look good on your 211, take care.
i'm not sure why your experience has proven such. i know that the bolt pattern
is the same (5-112), the center bore is same (66.5). what one needs to do is
to carefully determine that the new rim fit within the window of flexibility needed
to fit the rim with the car, taking into consideration...
- wheel thickness at the bolt seat (to determine lug bolt length need)
- ball seat size (to determine proper lug bolt ball seat radius)
- bolt hole diameter (to determine proper bolt size)
- wheel offset (to determine proper clearance...)
- tire size (to determine proper clearance and odo, speedo, cruise control
compatibility and readout....and compatiiblity if 4matic)
I am one who has success using 211 with 210, having fitted 2005 AMG rims
with my 99 E320. I purchased hybrid lug bolts from OtisInc who grafted
14mm ball seat onto 12mm bolt. Center bore has perfect fitment. I've used
this combo for over a year and every couple of months, I've pulled the rims
and carefully examined for scratches, wear, or any signs which might reveal
incompatibility. So far, fitment, use and operation has been solid.
raymond-
47º34'N 122º18'W
raymond- is offline   Reply With Quote
Old 03-08-2008, 11:47 AM   #12 (permalink)
ohlord's Avatar
Vehicle: 99 e320 wagon,bmw,vw,mgb,mg midget,subaru wagon
more
on w211
2001 Mercedes-Benz E320 - Using W211 Alloy Wheels
ohlord is online now   Reply With Quote
Old 03-08-2008, 11:55 AM   #13 (permalink)
Date registered: Aug 2007
Vehicle: W210 1998 E430
Perfect, ohlord, thanks.
C.
Benzboy210 is offline   Reply With Quote
Old 03-08-2008, 11:56 PM   #14 (permalink)
Date registered: Mar 2008
Vehicle: 2001 E320 Wagon
Beautiful rims. What is the market price for these rims? IS there a model number or on what year E class did they come in.
Originally Posted by gregs210 View Post
Your wish is the mini-mod's command...
yumling is offline   Reply With Quote
Old 03-09-2008, 08:18 AM   #15 (permalink)
torrem3's Avatar
Date registered: Oct 2006
Vehicle: 95 C280 Silver Metallic(champagne), 89 300E Onyx Mettallic<< All Options both w/car phones
Ohlord you are killing me I was going to search for the W211 Yilduz wheels when the dealer stopped me dead in my tracks by talking about the incompatibility. Aw heck its too late I am on my way to pick W210 wheels for my old faithful W124 and well I will leave the W211 Yilduz wheels for later in like 5-7 years when I can really afford them =O... =)
torrem3 is offline   Reply With Quote
Old 03-09-2008, 11:14 AM   #16 (permalink)
JCFair's Avatar
Date registered: Nov 2006
Vehicle: '00 E430 Sport, '01 SLK320
I purchased my '00 E430 Sport used with '03 W211 E320 16 inch wheels. I switch back to the original 17 inch wheels that came standard on the E430 Sport. I could not believe I was driving a car with a spare I could not use.
So if your new wheels require special lug nuts save the old ones for the spare.
W210 - Black and Black '00 E430 Sport
R170 - Cream and Salsa '01 SLK320
JCFair is offline   Reply With Quote
Old 03-09-2008, 11:45 AM   #17 (permalink)
Premium Member
acarter53's Avatar
Date registered: Dec 2006
Vehicle: 2001 E430 Sport in Desert Silver and 2002 C320 Sport Wagon in Arctic White
Premium Member
Send a message via Yahoo to acarter53
Question Greg
What is your lowering setup. Springs? Pad #?
E430 Sport
2001 E430 in Desert Silver with Sport Package, COMAND, Xenon Lights, Rear Sunshade, Heated Seats. Added K40 Stealth Radar, 30% Tint, XM Radio! www.premierbasement.com
acarter53 is offline   Reply With Quote
Old 03-09-2008, 01:45 PM   #18 (permalink)
ohlord's Avatar
That
spare tip about the lugs also came to me during the night,not only that but if you don't accurately plus size your rims and tires if you do have a flat the spare may be off in diameter enough to throw the abs, cruise control,out of whack.So drive very slowly till you can get the tire repaired.
Good tip JCFair
Old 03-09-2008, 04:46 PM   #19 (permalink)
Good point indeed! Probably saved a few people from one of those "This'll only take me a minute honey!.....oh.....fook. Uhm...honey, about this flat....uhm...." moments.
Old 03-09-2008, 07:02 PM   #20 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Wait, I'm confused.
My car's tool kit came with lug bolts for the stamped-steel spare. If you have a regular spare then yep, you'd better keep a set.
Take care and enjoy the ride,
Greg
FINAL DECISION TIME - RIMS! Synthetic R170 SLK Class 15 11-15-2007 04:16 PM
Will W211 rims fit on W210? farsal W210 E-Class 16 06-23-2007 09:18 PM
fitting W210 (12mm lug) rims on W211 (14mm lug)? schlol The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 05-04-2007 02:48 AM
Correct lug bolt for W211 stock rims for W210 application Raylee177 W210 E-Class 10 03-01-2006 09:58 AM
okay guys...i know we've been through this a million times..but i need a final consensus (more) confused W208 CLK Class 2 10-05-2001 07:51 AM
