Old 03-07-2008, 03:35 AM   #1 (permalink)
Date registered: Mar 2008
In car temperature sensor
Hello all and thanx for a great source of information.
I have a 1998 E320 wagon and just ran the A/C diagnostic and I get an Error code B1226 in car temperature sensor malfunction. When I read the sensor values then senor 1 reads "E" so I'm pretty sure it's malfunctioning.
Has anyone ever had this problem and do you know the fix?
Does anyone know the cost of this sensor if it needs replacing?
Best regards from Iceland,
Steindi
Steindi is offline   Reply With Quote
Old 03-07-2008, 10:48 AM   #2 (permalink)
ohlord's Avatar
Run
the tests again,post all the values and the errors.
How to Diagnose Air Conditioning Malfunctions | EclassBenz.com
when in error mode press both auto buttons at the same time to clear the error data.
Wait 15 minutes and run the tests again see if the error returns.
Are all the other values in range?
cabin temp sensor can often be vacuumed out with a shop vac and if that does not cure it
Your Parts Search Returned 2 Part(s)
it is an easy diy up by the rear view mirror in that little vent area.
good luck in Iceland
ohlord is online now   Reply With Quote
Old 03-07-2008, 11:50 AM   #3 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
Saying E rather than a reading probably means that the sender itself is bad. It comes with the fan, is not terribly expensive and is quite easy to replace. Once you get the lamp assembly off the roof, simply turn the sending unit 1/4 turn and it pops out.
Of course, your pushbutton unit could also be bad, but that's probably far less likely.
Outside Temperature Sensor... to loss W126 S,SE,SEC,SEL,SD,SDL Class 7 11-26-2007 01:27 AM
Temperature sensor idahomike Vintage Mercedes-Benz 0 02-05-2007 08:48 PM
Temperature Sensor tom_kauf W201 190E, D-Class 11 11-12-2006 04:00 PM
Outside Temperature Sensor dpaterso W140 S-Class 2 03-01-2005 01:33 PM
