Old 03-06-2008, 06:01 PM   #1 (permalink)
hiwaystar's Avatar
Date registered: Feb 2007
Vehicle: 1999 E320,1995 E320 Wagon,2000 M coupe,318TI,84 928S
Send a message via AIM to hiwaystar
remote keys no longer work
my 2 keys will know longer lock or unlock car or arm the alarm system. everything works fine when locked with manual key. all this started tuesday night when i tried to unlock the car in a bad storm i already have changed the battery in one of them, any ideas anybody
I don't give a damn what it was designed to do, what
can it do?
hiwaystar is offline   Reply With Quote
Old 03-06-2008, 07:55 PM   #2 (permalink)
ohlord's Avatar
Check
that the battery is installed properly in the key.If it is it might be a com problem in the system.Disconnect the battery neg lead through that little door in the rear pass foot well.step on the brakes for 30 seconds rehook up the neg lead,put the key in start the car turn the wheels all the way left to right a few times,enter the radio code and sync the windows and sunroof per the manual or in the tips or diy section.That will reset all the can bus systems and may solve the problem.
ohlord
Old 03-07-2008, 11:25 PM   #3 (permalink)
classioldy's Avatar
Date registered: Dec 2006
Vehicle: 82 240D; 98 E320; 97 E420; 85 190E gone; 88 300E gone.
or it culd be a simpler solution to it!
depending on the model year `til 97you have to sit inside the car
and point the remote to the reciber in the rear view mirror and press the button twice whitin 30 sec.and put it in the switch on the no.2 position and let it sit for a few seconds.
on newer models simply stick the remote in the switch on #2 position(whitout turn the engine on) and whait few seconds
in both cases the remote reprogram it self.
classioldy is offline   Reply With Quote
Old 07-23-2008, 05:03 PM   #4 (permalink)
Date registered: Mar 2006
Vehicle: 01 SLK230 and 99 E430
Question Ignition won't turn after keyfob batt replacement
I know this isn't exactly along the lines of this thread, but I have searched to no avail for my particular situation. First off, I have only one keyfob (I know, I know). Prior to our leaving town a few days ago (in another car) the LED was dimly lit full time on the keyfob. Upon our return the LED was out. I assumed it was telling me the batt was dead. I went to the stealership today and had the batts replaced in the keyfob. To my surprise it was only $15. When I pressed the buttons, the LED lit up brighter than ever. I was happily on my way. This evening I pressed the button and it still flashes brightly. The car unlocks the doors and opens the trunk fine as well as lowering the windows/opening the sunroof by IR. What it doesn't do is "unzip" the ignition lock when inserted as it used to. I guess I'll order a key tomorrow, but is there anything else I can try? I plan on opening the key up as I can see how the stealership gained access and see if anything looks strange. I rubbed the windows on both key and ignition, but I've never, never had this issue at all prior, so I can't imagine that it just starts up now. Any thoughts from this knowledgebase?
bikedoctor is offline   Reply With Quote
Old 07-23-2008, 07:38 PM   #5 (permalink)
Musikmann's Avatar
Originally Posted by bikedoctor View Post
...What it doesn't do is "unzip" the ignition lock when inserted as it used to...
That's a good way to describe the sound it makes when we insert the key. Are you saying that you cannot start the car as a result? From what I've read, the key will still start the car even with dead batteries. That's partly why the valet key (thin w/o batteries if your car came with one) will work for the valet but do nothing else.
Old 07-23-2008, 07:53 PM   #6 (permalink)
Correct. Key won't turn at all. So am I to believe that the IR port in the key and the IR port in the ignition serve no purpose or is it, perhaps, my key malfunctioning. I have no valet key, so I know not of what you speak. If a valet key functions perfectly aside from unlocking, why pay $200 for a new one? It just seems logical to me that something is up with the key getting "clearance" since the batts were just changed. Is there a procedure after changing batts?
Old 07-23-2008, 08:21 PM   #7 (permalink)
Musikmann's Avatar
In my opionion, your key is malfunctioning due to the crumpled metel contact strip you have. Because the valet key will only start the car, no lock/unlock, trunk open, panic, etc. There is no procedure to follow after changing batteries, it should still work.
Old 07-23-2008, 09:21 PM   #8 (permalink)
No valet key here to compare. I have a key that will do everything, but turn the ignition. I'm wanting a new key anyway, so we'll see what happens...
Old 07-24-2008, 03:15 PM   #9 (permalink)
Musikmann's Avatar
Good Luck, and the new chrome keys are nice.
Old 07-24-2008, 03:29 PM   #10 (permalink)
me beautiful's Avatar
Date registered: Jun 2008
Vehicle: E300TD 1997 W210 Running on chippie oil at 99.8%
Hello, I don't know about your key shape but I have an old model style, when you open it the coil at the end is quiete large (compare to the new teeny key in the chrome one). I had the same problem then yours and realise that the "hair thin" copper wire around the end was kind of disconnected. I took it off completely, weld it at one extremity, wrap it around the end snuggly, and weld the other end to the other side. I might not make much sense but if you open your key and look inside you might have the "large" coil at the end. Mine is a 1997 E300.This might be your solution. Just make sure the wire is welded properly and fit snuggly. All the best. Keep us inform. Olivier
me beautiful is offline   Reply With Quote
Remote Keys Broken? MAUIRIDER W163 M-Class 10 10-19-2006 05:21 PM
second hand,used Flip remote keys re-programming lofty General Mercedes-Benz 7 04-27-2006 02:53 PM
Difinitive Answer on Remote Keys - Maybe! larryk R170 SLK Class 0 09-13-2005 01:58 PM
s320 Alarm Remote Control POOR Range I have to place the remote up to the class to get it to work. supersel W140 S-Class 16 02-06-2005 10:48 PM
remote control keys bazzis R170 SLK Class 2 12-22-2003 12:13 PM
