Old 03-05-2008, 09:57 PM   #1 (permalink)
benzcouple's Avatar
Date registered: Dec 2007
Vehicle: 1997 mercedes e420
alarm on e420
hello all is there a fatory alarm on 1997 e420, it saod it had one in our owners manual, but how does it work???????
benzcouple is offline   Reply With Quote
Old 03-05-2008, 10:03 PM   #2 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
Since you've never heard it, I have to assume that it's similar to my '96 E300. I wasn't sure it worked until I set it off by accident while sitting in the car.
Try sitting in the car, and lock the car with the remote. Then open the door. You might want your remote handy to turn it off.
Old 03-05-2008, 11:31 PM   #3 (permalink)
Kajtek1's Avatar
Vehicle: E300DT/320cdi ML320/55
As far as I know all MB alarms arm automatically with remote. When you use mechanical key, it will not arm. Using valet key to open will trigger the alarm, till you insert the key into ignition.
Kajtek1 is offline   Reply With Quote
Old 03-05-2008, 11:58 PM   #4 (permalink)
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
Yes factory alarm included...To test ^^see above post
JOE55 is offline   Reply With Quote
Advice....E420 1995 vs E420 1996 and up radunegru W124 E,CE,D,TD Class 14 06-30-2008 09:28 AM
Looking for '95 E420 TPK W124 E,CE,D,TD Class 0 06-29-2007 05:56 PM
Can the factory alarm be codes so that it beeps when the alarm is engaged and the light flash HACK THT W163 M-Class 0 03-18-2006 08:10 PM
Audio clip of the panic alarm - alarm + Hella air horns... Drew W163 M-Class 0 10-10-2003 07:35 PM
New E420!! OBX884 W210 E-Class 0 06-25-2003 05:33 PM
