Old 03-05-2008, 12:54 PM   #1 (permalink)
Date registered: Dec 2007
Vehicle: Mercedes Benz E420
Failed Inspection for OBD/Emissions System
I went thru inspection today in NJ and they told me that i failed for a OBD/Emissions system failure can someone shed some light on this and to what should i be expecting to fix.
blackstarr777 is offline   Reply With Quote
Old 03-05-2008, 01:35 PM   #2 (permalink)
Date registered: Dec 2006
Vehicle: 1997 E320, 1997 S320
is your cel on? did you check for any codes?
tirona is offline   Reply With Quote
Old 03-05-2008, 01:44 PM   #3 (permalink)
Nothing is on my car is free of any cel error codes. After doing some research in the forum i read a post that the NJ Inspection States have a problem interfacing with ODBII system in the Mercedes. So i'm trying to find a solution
Old 03-05-2008, 03:58 PM   #4 (permalink)
TNTRower's Avatar
Date registered: Sep 2007
Vehicle: 1998 E320 Wagon
Also if you had recently disconnected the battery or otherwise lost electrical, it would cause the ECU to tell the OBD scanner "Not ready for testing" or some such thing. In order for you to get rid of that you need to drive the Car about 100 miles or so. Then go back and get it tested again.
Drew
Who's John Galt.
"Timeo Danaos et dona ferentes" - Virgil, The Aeneid, Book 2
TNTRower is offline   Reply With Quote
Failed emissions inspection Htown W126 S,SE,SEC,SEL,SD,SDL Class 71 04-12-2008 12:51 PM
Carfax says "Failed emissions inspection" in NY (diesel) robricc W210 E-Class 5 04-10-2007 07:06 PM
Help! I failed emissions inspection! bigdaddyd300se W126 S,SE,SEC,SEL,SD,SDL Class 22 05-19-2006 06:52 PM
emissions inspection steven t lee R170 SLK Class 1 01-29-2006 01:20 PM
failed emissions inspection thinkpeace9 W124 E,CE,D,TD Class 10 11-26-2004 06:06 PM
