Old 03-04-2008, 08:53 PM   #1 (permalink)
AlphaFive's Avatar
Date registered: Mar 2008
Vehicle: 1998 S500 W140
Rough engine idle in a 1998 E320
I'm new to Benz World and this is my first post.
My wife just bought a 1998 E320 with 86,122 miles. The engine seems to be idling a little rough. I thought that it might be the engine mounts but when your driving it sound fine. Also when it's in park it sound fine. It only happens when your in drive and stopped(like at a red light). It sound rough like a deafening humming. The steering wheel doesn't shake much but you can definitely feel shaking in the dash and in the seats.
So, I'm a new Mercedes-Benz owner myself and I'm wonder is this a serious problem or can this be fixed by recalibrating the RPM s to Idle correctly?
Any suggestions or tips are appreciated! Thanks for reading.
AlphaFive is offline   Reply With Quote
Old 03-04-2008, 11:24 PM   #2 (permalink)
Date registered: Feb 2008
Post
Hi,
This does sound like Engine mounts & you won't feel them much while driving more likley when idling you will feel the roughness/ vibration!
hope this helps!
rickmikhael is offline   Reply With Quote
Old 03-05-2008, 04:19 PM   #3 (permalink)
AlphaFive's Avatar
Thanks for the feed back. Yeah i was hopeing that was not the case. I got an appointment with a mech on friday. Will post results, cost, that sort of thing.
Thanks
Old 03-05-2008, 05:30 PM   #4 (permalink)
ohlord's Avatar
Diy
in the diy section,mounts are only 50 bucks a side from autohausaz.com
usually you would have a check engine light if it was a misfire issue.Sounds like mounts,inspect the spring perches while down there.
Get the trans serviced mb fluid only
ohlord
ohlord is online now   Reply With Quote
1995 e320 rough idle 1995e320special W124 E,CE,D,TD Class 8 10-24-2007 11:38 AM
'02 E320 Severe hesitation and rough idle JRNF W210 E-Class 1 05-17-2007 02:20 PM
1998 E320 vibration at idle (in gear) Texas General Mercedes-Benz 1 10-10-2006 08:49 AM
E320 97 Rough Idle e32097 W210 E-Class 5 10-18-2005 04:09 AM
Low idle, rough idle, stalling, hot and cold start solved: E320/300 rvenerac W124 E,CE,D,TD Class 5 06-04-2004 02:12 PM
