Old 03-04-2008, 01:09 PM   #1 (permalink)
Date registered: Feb 2008
Vehicle: 1998 Mercedes E200
Post E200 1998 (W210) Rear Diff Oil Leak
Hi all,
I just purchased an E200 W210 and love it. I just had it serviced and while the mechanic had it up on the ramp he noticed a leak in from the rear axle which he tells me is a gear oil leak from the differential..... He tells me that I now need to get a replacement rear axle.
I just bought the car and was about to put it in for it's NCT (The Irish equivelent of an MOT) but it will fail on this. Do I really have to replace the rear axle or is there anything else I can do?
Any help would be much appreciated.
armstrob is offline   Reply With Quote
Old 03-04-2008, 01:13 PM   #2 (permalink)
Date registered: Jan 2007
Vehicle: 2005 S500 4matic Sport Designo
well for one, you don't have to replace the rear axle, and two, how big is the leak?
IF this mechanic is recommending a complete axle replacement as opposed to just a diff reseal, he is trying to hose you. I would run, fast.
OliverK is offline   Reply With Quote
Old 03-04-2008, 01:18 PM   #3 (permalink)
Oliver,
Thanks a million for your quick reply. The leak seems to be about a drop or two a day based on the ground stain. He refilled the gear oil today and told me to come back in about 4 weeks to see how bad it is. Can the seals be just redone? If so is it a really big job?
The mechanic told me to source a reconditoned unit and it would take him a couple of hours to fit. If I could just get seal done I would much rather prefer that.
Old 03-04-2008, 03:03 PM   #4 (permalink)
Date registered: Apr 2007
Vehicle: 2001 SLK 320(96K Miles), 2002 E320 Special Edition(113K Miles)
If yougot no other problems, just replace the leaking seals. You have no control over how well the reconditioning was done, so you may end up worse (whine, clunk, etc). Both the pinion seal and the sideshaft seals can be replaced. Find out which is leaking - probably the pinion seal.
Only two thing are infinite, the universe and human stupidity, and I'm not so sure about the former.
Albert Einstein
Honest politicians (and lawyers) are like UFOs. Most people believe that there must be some out there somewhere, but nobody has yet been able to prove their existence.
Kobus is offline   Reply With Quote
Old 03-05-2008, 08:31 AM   #5 (permalink)
Thanks a million for your help guys. I am getting the seals checked by another mechanic and getting them all replaced to be safe.
1998 E320 Oil Leak cleverpig W210 E-Class 10 10-01-2008 10:50 AM
W210 E420 Diff Oil sidmon W210 E-Class 23 07-15-2008 11:59 AM
Diff oil leak Kobus W210 E-Class 8 05-26-2007 03:15 AM
Rear diff leak, please give advice PUPU W163 M-Class 1 01-10-2007 05:15 AM
oil leak from diff, any help? fabslk007 R170 SLK Class 2 03-09-2005 10:43 PM
