Old 03-04-2008, 07:36 AM   #1 (permalink)
brianmohr's Avatar
Date registered: Mar 2008
Vehicle: 2001 E430
strange leak
Need a bit of help troubleshooting this thing. I have a 2001 E430 (now my wifes car). She was rear ended a few days ago and not driven until I can replace the back cracked light lens. Anyway, when I reparked the car yesteday I noticed a small amount of "fluid" under the front of the car. I looked closer and found that a good bit of this "fluid" has puddled just infront of the engine right under all the fan belts and whatnot. Puddled more on the window washing fluid reservoir side. Could this be a power steering o ring blowout? Any help would be great. And sorry for the vague description. I have never worked on these cars, only my 996 911 and things are much different between the two Thanks in advance!
brian mohr
annapolis MD
brianmohr is offline   Reply With Quote
Old 03-04-2008, 07:43 AM   #2 (permalink)
livefreeordie's Avatar
Date registered: Oct 2007
Vehicle: 02 SLK230 Komp. 08 Honda CRV
A good start for locating the leak would be to find out what color the fluid is, also put some on your finger and see if its oil base or water base.
livefreeordie is offline   Reply With Quote
Old 03-04-2008, 07:52 AM   #3 (permalink)
brianmohr's Avatar
Vehicle: 2001 E430
stange leak
I did..it almost looks blueish and is def a lubricant. Feels greasy. And it's not the washer fluid
bmohr
Old 03-06-2008, 01:51 AM   #4 (permalink)
Check the power steering and break fluid.
Old 03-06-2008, 04:54 AM   #5 (permalink)
brianmohr's Avatar
Vehicle: 2001 E430
strange leak
will do. Thanks for the input!
bmohr
Old 03-11-2008, 05:17 AM   #6 (permalink)
brianmohr's Avatar
Vehicle: 2001 E430
it was the radiator 800 bucks to replace by indy mechanic. 400 dollar part.
Old 03-11-2008, 05:24 AM   #7 (permalink)
Glad you found the problem, to bad it cost so much.
Old 03-11-2008, 09:57 AM   #8 (permalink)
Kajtek1's Avatar
Vehicle: E300DT/320cdi ML320/55
400 is nothing for bigger part on MB.
I spend more for cigarette pack -sized pedal positioning sensor.
Household dimmer potentiometers with all the electronics cost $5
Kajtek1 is offline   Reply With Quote
Old 03-11-2008, 02:24 PM   #9 (permalink)
ohlord's Avatar
Wow
somebody got marked up.OE radiator from radiator.com 200 bucks.OEM from germanstar.net about $259,a diy job for sure and definitely not a 400 buck labor plus the extra profit on the radiator job.
I guess ya gotta do what ya gotta do.
Don't let him replace the mass air sensor for you he might charge you 500 bucks for a 10 minute r/r and a 160 buck part.
did he check why the radiator failed?If he did not find the cause the problem may repeat.
ohlord is online now   Reply With Quote
Old 03-11-2008, 06:17 PM   #10 (permalink)
Date registered: Jun 2007
Vehicle: 1999 E430, 2006 Escalade ESV
I need a radiator replaced also. Quoted a price of $430 by a radiator specialist shop. The indy shop wanted $725. I think your $800 is too much.
Every summer vacation should start with 5 whiny passengers in a drive from Sacramento to Las Vegas.
1999 E430
AlphaWolf is offline   Reply With Quote
Strange Coolant Leak trimaster1 General Mercedes-Benz 16 09-07-2007 11:15 PM
Strange Brakes and strange noise from car micosavo W210 E-Class 9 06-18-2007 05:55 AM
Wiring loom - insulation falling off, water leak, oil leak sjc123456789 W124 E,CE,D,TD Class 3 02-10-2006 11:24 AM
strange engine sound - together with strange smell under hood? quepao W163 M-Class 2 01-23-2006 09:31 AM
My car is in the shop...Oil leak, windshield washer leak, and screw came off. chanm W163 M-Class 3 05-23-2003 07:21 AM
