Old 03-03-2008, 07:04 PM   #1 (permalink)
mr diesel's Avatar
Date registered: Jul 2004
Vehicle: 1997 E300D
Send a message via AIM to mr diesel
Exclamation E 300 Diesel belt adjuster
has any one replaced it, mine is rattling real bad it is very hot to the touch (the one on the right side) or do i have to replace the whole thing as a unit (both)???
1997 E300D
mr diesel is offline   Reply With Quote
Old 03-04-2008, 09:48 AM   #2 (permalink)
Kajtek1's Avatar
Vehicle: E300DT/320cdi ML320/55
You can't buy small part in US anymore. For 93 model I could buy Power steering pump rebuild kit for $39. For W210 you have to buy whole pump for $600.
If you have time you could pull out the bearing and trying to match it at industrial supply.
Good luck
Kajtek1 is offline   Reply With Quote
Shoulder Belt Height Adjuster smack W126 S,SE,SEC,SEL,SD,SDL Class 2 08-02-2007 02:28 PM
w211 seat belt adjuster splang W211 E-Class 0 10-28-2006 11:58 AM
Drivebelt Belt Adjuster Replacement Stevie A W201 190E, D-Class 2 10-10-2005 03:58 PM
Performance issue: 5 cylinder 300 turbo diesel vs. 6 cylinder 300 diesel Cyberbach W124 E,CE,D,TD Class 22 10-10-2005 01:59 AM
1987 300 Diesel - 3 rd rear seat belt? dcarl43677@aol.com W124 E,CE,D,TD Class 2 01-25-2003 08:19 AM
