Old 03-03-2008, 06:36 AM   #1 (permalink)
Date registered: Aug 2006
Unhappy ESP Stuck on "Stupid"
The Mrs. left the lights on and let the battery run down. I got the motor club to start it up and did all the usual resets; turn the wheel lock to lock, press and hold the window buttons, enter the radio code, blah blah blah.
The ESP warning light won't turn off and the engine will not rev past idle. Very frustrating.
I let the car run to charge things up and according to the A/C diagnostic panel, the battery voltage is 13.5V.
Ideas?
marrerel is offline   Reply With Quote
Old 03-03-2008, 07:26 AM   #2 (permalink)
larces's Avatar
Date registered: Feb 2008
Vehicle: w210 1999 E320 black
Send a message via MSN to larces
did you try to make it drift so the esp control get activated ? the light blinks or stay solid ?
LOU
larces is offline   Reply With Quote
Old 03-03-2008, 08:15 AM   #3 (permalink)
ohlord's Avatar
Running
it to charge adead battery is about the worst thing you can do to both the battery and the alternator.Get it on a charger at least 10 hours at ten amps.Key out while on charge and then do the reset.
ohlord is online now   Reply With Quote
Old 03-04-2008, 11:24 AM   #4 (permalink)
Thanks Lou. I'd love to make it drift but I would need some horses and an icy road. It will *not* exceed 1500RPM no matter what you do.
Exclamation point is on steady.
Old 03-04-2008, 11:25 AM   #5 (permalink)
Thanks ohlord,
Gotta find someone with a charger.
Old 03-04-2008, 12:10 PM   #6 (permalink)
ohlord's Avatar
Key -out- while
on charge if I did not point that out.
harbor freight charger good for what you need
Harbor Freight Tools - Quality Tools at the Lowest Prices
Old 03-04-2008, 03:45 PM   #7 (permalink)
Date registered: Apr 2006
Vehicle: 00CLK320 (mine) 00E320 (wife) was 94 & 95 C280 (sold both).
Run it as normal in a few days (just ignore the stupid ESP light), it reset itself after a few cycle of stop & start (in my case, on me CLK). Good luck.
00CLK208 is online now   Reply With Quote
"Stupid Question" What is the right tire pressure? Heretic E55 W210 E50 AMG, E55 AMG 8 12-03-2007 11:07 PM
My 2004 C240 "ESP MALFUNCTION LIGHT" is on. Help? pane66 General Mercedes-Benz 3 04-17-2007 03:16 AM
Dealer found cause of my "BAS/ESP" light coming on, and its not the brake lamp switch... S4toML W163 M-Class 7 07-14-2003 05:58 PM
Follow up on BAS/ESP/ABS lights and "B" service. Chris Krikorian W163 M-Class 0 10-25-2002 04:29 PM
