Old 03-02-2008, 09:01 AM   #1 (permalink)
Ben Parrish's Avatar
Date registered: Feb 2008
98 E-320 wagon misfire torture--update
I had a problem a few weeks ago. Had codes that related first to cyl3 misfire, the 1 and 2. I replaced all the plugs and the wires and coil packs for all three cylinders(apparantly prematurley) and all seemed fine. Cleard the codes and went on my way. Well, the CEL light and "Check engine electronics" meassage came back. OBD says misfire on cyl 1 and 2.
I suspect either the cats or a fuel delivery problem is to blame. In a previous thread, OhLord spoke about listening to the fuel rail on either side to see if there was a difference in sound; I will do that in a little while. I don't hear any ratteling in the cats but they are still suspect(126,000 miles).
What is the procedure for checking the cats with a laser tem probe. What should the pre and post readings be?
Any other suggestions?
I want to avoid the dealer and I live in a rural area that doesn't have a indipendent Mercedes shop.
thanks,
Ben
Ben Parrish is offline   Reply With Quote
98 E320 wagon misfire torture...HELP Ben Parrish W210 E-Class 8 02-12-2008 03:26 PM
98 E320 Wagon Misfire Ben Parrish General Mercedes-Benz 0 02-12-2008 12:47 PM
an Update on my misfire/rough idle skipinschool W140 S-Class 6 09-12-2007 06:29 AM
Bush makes important speech on torture, saying "We do not torture" kvining Off-Topic 13 11-09-2005 11:13 AM
320 GRILL UPDATE CaliE320 W124 E,CE,D,TD Class 10 03-20-2003 02:58 PM
