Old 03-01-2008, 08:40 AM   #1 (permalink)
Date registered: Feb 2008
Vehicle: 2000 E430 sport
climate control
does that part have light? where the display is at how many degrees you want to set
dylokjai is offline   Reply With Quote
Old 03-01-2008, 09:03 AM   #2 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
Remove the pushbutton unit with radio keys, and the bulb is on the bottom.
Old 03-02-2008, 08:03 PM   #3 (permalink)
larces's Avatar
Vehicle: w210 1999 E320 black
Send a message via MSN to larces
also taking about fan control a friend of mine has a e430 that have the ac velocity control broken somebody knows we're i can find one ???
thanks
LOU
larces is offline   Reply With Quote
Old 03-02-2008, 10:38 PM   #4 (permalink)
thanks Matt! i went to Kragen and bought some sylvanna 2721 for 1.99 instead of 8.99 at the dealer
Heat Stuck on, Climate Control Panel/Climate Control Servo Problem? 123Doug W123 E,CE,D,CD,TD,TE Class 15 09-18-2007 01:15 AM
climate control? kickboxer W126 S,SE,SEC,SEL,SD,SDL Class 0 11-08-2006 04:03 PM
climate control davesbenz W126 S,SE,SEC,SEL,SD,SDL Class 2 11-22-2005 06:56 AM
cruise control vs. climate control CCarlisle W123 E,CE,D,CD,TD,TE Class 0 11-04-2005 10:51 PM
Climate Control MyBenz W123 E,CE,D,CD,TD,TE Class 9 04-11-2004 08:29 PM
