Old 02-29-2008, 08:45 PM   #1 (permalink)
Date registered: Apr 2007
Vehicle: 1996 MB E320, 1989 BMW 735il, 1995 BMW 320i
Angry HEATER FAN...
Greetings to all my fellow W210 owners!!!
I have a 1996 E320 and have a question about the heater fan that needs answers . Lately it stopped blowing air, temp works fine, nice and warm or I can change it to a nice and cold temp. The problem is that the air doesnt come out with any pressure. If I crank it up full blast, it still comes out as if it were on low.
I took it to a few shops, one guy says assumed it was a seized fan and requires new resistors, costing roughly $800. Another guy said it was my center control unit, costing $1000. A friend said it could be something to do with just the fuse box, with a burnt or missing fuse. Any ideas from my fellow benz lovers??
I live in Toronto, Canada, finding a good, honest indie shop has been a problem since I got this car, any recommendations??
AMG POWER is offline   Reply With Quote
Old 02-29-2008, 08:55 PM   #2 (permalink)
livefreeordie's Avatar
Date registered: Oct 2007
Vehicle: 02 SLK230 Komp. 08 Honda CRV
Try the fuse first, if not the fuse it may be the rheostat which controlls the fan speed.
livefreeordie is offline   Reply With Quote
Old 02-29-2008, 09:01 PM   #3 (permalink)
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
Is there any error codes?....Btw cool user name you got!
Please complete your BW PROFILE - Vehicle Yr & Model and Location when you get a chance.
Cheers,
JOE55
JOE55 is offline   Reply With Quote
Old 02-29-2008, 09:24 PM   #4 (permalink)
Voltage Regulator. The early version of the voltage regulator is attached to the blower motor. They have been retro fitted and are now seperate. Hence you will need a new voltage regulator, a new blower motor and a new cover. That is expensive. sorry.
mdw123 is offline   Reply With Quote
Old 02-29-2008, 09:40 PM   #5 (permalink)
ohlord's Avatar
The
fan works but only low speed?So it is not the fuse.The regulator must be bad.Look in the diy section.$500 bucks for the upgraded parts autohausaz.com if the fan was shot or in this case since it works the cheapo fix
Early W210 Blower Motor Regulator Replacement DIY Here... - MBWorld.org Forums the use of the other model unit.So if the fan is blowin but only on low,it is good,just do the fix above and you are good to go.
ohlord
see common issues for more info
Mercedes-Benz W210 - Wikipedia, the free encyclopedia
and unhook the battery so we don't have to fix anything fried during the repair
that's the blower motor regulator to correct the member above not the voltage regulator
ohlord is online now   Reply With Quote
Old 02-29-2008, 09:54 PM   #6 (permalink)
ohlord's Avatar
Drive
Down to Buffalo
One of the members had a shop he trusted down there.
Or get out the tools and dig in
Old 03-01-2008, 12:31 AM   #7 (permalink)
Vehicle: 2001 SLK 320(96K Miles), 2002 E320 Special Edition(113K Miles)
Also look at these 2 links. The second also has the part number.
http://www.benzworld.org/forums/w210...ower+regulator
http://www.benzworld.org/forums/w210...enly-slow.html
This link got some nice pictures:
Only two thing are infinite, the universe and human stupidity, and I'm not so sure about the former.
Albert Einstein
Honest politicians (and lawyers) are like UFOs. Most people believe that there must be some out there somewhere, but nobody has yet been able to prove their existence.
Kobus is offline   Reply With Quote
Old 03-01-2008, 11:35 AM   #8 (permalink)
Thank you guys soo much!!! I'm going to place my order for a 140 regulator from autohuaz and adapt it to fit my w210 myself. Thank you both OhLord (who helped me out dozens of times) and Kobus for the pictorial DIY.
By the looks of what I am reading from all the links you guys showed me, I am having the exact same symptoms as everyone else who did this DIY repair. The fan seems to work, only at limited capacity, so hopefully his new regulator should solve my problem. I am so happy this fix just went down from $1000 to only $200. I will keep you all posted on my progress, and thanks for your interest in helping out!!
Old 03-01-2008, 01:20 PM   #9 (permalink)
ohlord's Avatar
Also
I did not think of it since your's is a 96 but a check of autohausaz.com shows you have the cabin and charcoal pollution filters on the 96 and if the cabin filters are very dirty and have not been changed for years it may be the problem(sort of like blowing a fan through a blanket) and you have no need for the regulator,wouldn't that be nice
diy to check them is in the diy section,pull them out and see if the blower blows full speed.If dirty and the fan still won't go up to speed replace them anyway it is time.
Heater fan Donal Hayes V-Class 2 12-05-2007 04:29 AM
Heater fan issues white500se W116 S, SE, SEL, SD Class 8 11-09-2005 12:22 PM
Heater Fan Grease? 500MPL W126 S,SE,SEC,SEL,SD,SDL Class 1 10-23-2005 07:38 PM
126 HVAC Fan not working / Heater Fan Removal cam69ss W126 S,SE,SEC,SEL,SD,SDL Class 1 01-25-2005 11:31 AM
Heater/Fan noise Tjærand G-Class 4 06-04-2002 10:46 AM
