Old 02-28-2008, 11:22 PM   #1 (permalink)
Date registered: Sep 2006
Vehicle: 2001 E200K
Transmission question
I recently took a road trip and discovered that at speed above 100km/h my car take long to shift from 4th to 5th. Even if I lift off to try and get it to change, it simply slows down but does not shift.
The car has 80 000km on the clock and I've had it since 40 000km. I'm not sure whether the transmission was serviced before. Will a service help resolve the problem or it could be something more than that??
cisaacson is offline   Reply With Quote
Old 02-29-2008, 12:03 AM   #2 (permalink)
ohlord's Avatar
should be in overdrive before 100
kmh fluid change may help but with so low miles it may be time to have line pressures and shift points checked.adjustments can be made.
ohlord is online now   Reply With Quote
Old 02-29-2008, 02:53 AM   #3 (permalink)
Kajtek1's Avatar
Vehicle: E300DT/320cdi ML320/55
Those transmissions are "Driver adaptive". If you use the engine for strong acceleration and braking a lot, it is going to hold the gears for longer. I have the issue a lot after mountain driving.
I just serviced transmission on my E300D at 240,000 miles and fresh fluid with lower viscosity softens the gear changes, but doesn't change the computer shifting.
Kajtek1 is offline   Reply With Quote
Old 02-29-2008, 05:51 AM   #4 (permalink)
Vehicle: 2001 E200K
Thanks guys
I've been driving as usual, what amazes me is that even lilfting my foot to force the shift doesnt work at speeds above 100km/h. At lower speeds shift into 5th is as normal. I will certainly take it in to the shop.
Transmission Question PH19 W210 E50 AMG, E55 AMG 4 10-09-2007 02:04 PM
Another transmission Question Louie_D W126 S,SE,SEC,SEL,SD,SDL Class 5 04-18-2007 07:38 AM
transmission question chahonda W116 S, SE, SEL, SD Class 17 07-24-2006 12:12 AM
Automatic transmission question: anyone knows how to make the transmission shift at a higher RPM, DanPro1 R170 SLK Class 8 10-07-2002 03:35 PM
32 transmission question... SteveL R170 SLK Class 5 10-21-2001 09:51 AM
