Old 02-28-2008, 12:50 AM   #1 (permalink)
Date registered: Feb 2008
Quick Question
hey all
quick question my abs/esp is not working at all lights and malfunction messages are appearing in my 02 e320
is this a brake switch problem does a brake switch malfunction cause the abs/esp to not function at all?
and is there a way to tell if it is the brake switch which is causing this problem?
any help is very much appreciated
thanks
capone345 is offline   Reply With Quote
Old 02-28-2008, 03:15 AM   #2 (permalink)
ohlord's Avatar
First check
your batttery output.Go to How to Diagnose Air Conditioning Malfunctions | EclassBenz.com
and run the first set of the test.Value #24 is your battery voltage while running.
It should be above 13.If lower than 13 your abs will stop working and turn on the warning lights.If above 13 get the switch and do the diy you have already read about.
step on the brakes,do you have brake lights?
ohlord is online now   Reply With Quote
Old 02-28-2008, 11:26 PM   #3 (permalink)
while the car is on my 3rd brake light stays on when i dont even press it when i press it the 3rd brake light turns off
Old 02-29-2008, 12:36 AM   #4 (permalink)
ohlord's Avatar
Switch
is toast,replace it and you should be good to go
always remove key after moving seat all the way back to work under the dash then do this
Electrical
when ever working on the electrical system and when done rehook it up and sync windows etc per the instructions in your manual
http://www.analogstereo.com/pdf/om/m...anual_2002.pdf
in case you don't have the manual^^^^^
ohlord
Old 02-29-2008, 01:14 AM   #5 (permalink)
Electrical
ohlord
thank you but do you mean the switch is toast???
Quick Question SoLe s320 W140 S-Class 9 12-29-2007 08:58 PM
quick question.. breakaway16 General Mercedes-Benz 1 09-01-2006 11:08 AM
quick question sirsucknasty W124 E,CE,D,TD Class 3 11-22-2004 08:49 AM
quick question blue420sel W126 S,SE,SEC,SEL,SD,SDL Class 4 09-10-2004 06:16 AM
Quick Question 04Mercedesbenze55 W211 E-Class 1 11-04-2003 05:02 PM
