Old 02-27-2008, 09:50 PM   #1 (permalink)
TNTRower's Avatar
Date registered: Sep 2007
Vehicle: 1998 E320 Wagon
Ticking Lifters 112 Engine
Hi Guys!
I have been poking around. I am trying to find any info on Ticking Lifters for a 112 engine. This is my 98 E320 Wagon. I saw the write up for the 119. The problem is I can not find the Oil Guides at Autohaus so I was wondering if we even have them on the 112?
Any thoughts y'all?
Who's John Galt.
"Timeo Danaos et dona ferentes" - Virgil, The Aeneid, Book 2
TNTRower is offline   Reply With Quote
Old 02-27-2008, 10:52 PM   #2 (permalink)
ohlord's Avatar
no
conventional galleys and oil passages.Throw in a bottle of atf fluid run it at an idle for 15 minutes and drain and change the oil if you can find 5w40 mobil syn try it and see if it helps those worn cam followers.
ohlord
18 Lubrication
ohlord is online now   Reply With Quote
Old 02-28-2008, 07:59 AM   #3 (permalink)
Date registered: Jan 2007
Vehicle: 2005 S500 4matic Sport Designo
are you sure its the lifters?
Injectors are pretty loud these days
OliverK is offline   Reply With Quote
Old 02-28-2008, 02:03 PM   #4 (permalink)
Sergio's Avatar
Date registered: Sep 2002
Vehicle: 1995 E320
An oil & filter change using Mobil 1 0W-40 or 10W-40 does wonders!
Sergio
'95 E320 SE
'99 ML430 (gone)
'01 E320 Wagon 4-Matic
'94 C280 (R.I.P)
Sergio is offline   Reply With Quote
Old 02-28-2008, 02:05 PM   #5 (permalink)
TNTRower's Avatar
Does anybody REALLY know anything...
I mean not to sound overly philosophical but what do we really KNOW? All kidding aside. I am assuming it is lifters because it is localised. If it were injectors and they were noisy because of design wouldn't it stand to reason that they would all be noisy? I am seriously asking and not trying to be a weisenheimer.
As for the ATF solution does it matter what ATF I use? I have a 2/3 full case of Mercon Dexron III. Can I just use that stuff?
Also, I did the oil change myself when I first got the vehicle. Mobil 1 0W40 was what I put in.
Old 02-28-2008, 02:23 PM   #6 (permalink)
well, your post wasn't terribly specific about how you know its the lifters.
Old 02-28-2008, 02:36 PM   #7 (permalink)
TNTRower's Avatar
And I appreciate your looking at the big picture.
Old 02-28-2008, 03:25 PM   #8 (permalink)
ohlord's Avatar
The
dex is fine 1 qt. and then change the oil.
Old 02-28-2008, 03:31 PM   #9 (permalink)
Date registered: May 2005
Vehicle: '07 GL320CDI, '06 E320CDI
Why not subscribe to WIS and read the bulletins?
Same thing is buying the service DVD.
Contains a couple bulletins about engine ticks.
One is incorrect head gasket (piston hits)
One is exhaust valve hydraulic elements at cold start
Kent Christensen
Albuquerque
Old 02-28-2008, 05:27 PM   #10 (permalink)
TNTRower's Avatar
Smile
For the same reason that you get second opinions from Doctors. Besides, I enjoyt the witty reparte. There are a lot of owners here who have done things any number of ways. I like to read what people's different take on things are.
As the old cliche goes, there is more than one way to skin a cat (as barbaric as it sounds, although they do taste good scattered, smothered, and chunked). To that end, why subscribe to the WIS and solely rely on that for the only information? If you were to do that then it would be logical to say that the only acceptable way to maintain one of these beauties is to take it to the dealer for everything. I prefer to take a more egalitarian approach and draw upon the knowledge of the enthusiast community. The WIS is a very important and valuable tool, as is the forum.
Just my $.02
Fs: 112 Engine Intake Manifold W/injectors And Throttle Valve Benztech327 For Sale, Trade & Wanted Items 0 03-19-2007 01:41 PM
Ticking sound from the engine srmalek W210 E-Class 10 11-15-2006 10:58 AM
What diag scanner for my ML320 112.9423 engine andrew_zaf W163 M-Class 0 09-23-2006 02:25 AM
Lifters Ticking? Engine Sound? mafiaconnected W210 E-Class 5 01-17-2006 11:01 AM
ticking lifters and smoke? eMLi W163 M-Class 13 06-18-2003 03:43 PM
