Old 02-27-2008, 03:29 PM   #1 (permalink)
Date registered: Jan 2007
Vehicle: 2005 S500 4matic Sport Designo
fuel gauge issues
I have a very minor issue with the fuel level gauge.
When I fill the tank, the gauge reads full as it should. However, after driving as little as 15 miles, the needle reads 7/8ths full.
The last quarter tank seems to be about 6 gallons though, indicating that its a touch off.
Is there any way to fiddle with the sender to fix this?
when I get to the tank, what should I be looking to do?
thanks
OliverK is offline   Reply With Quote
Old 02-27-2008, 05:28 PM   #2 (permalink)
Date registered: Dec 2007
Vehicle: E320 4 Matic 2001
I also have a fuel gage problem.Mine is when I fill up it only goes to the last line but not all the way up. The tank is full but the gage doesn't indicate as full.
Hi Fi is offline   Reply With Quote
Old 02-27-2008, 06:01 PM   #3 (permalink)
Musikmann's Avatar
I think both of you have a sending unit problem but I don't remember reading about any fixes on here; typically, I think people just replace them. Hopefully someone will know of a way to fix or tweak them back to accuracy. Good Luck!
Old 02-27-2008, 06:14 PM   #4 (permalink)
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
^^1+...yes it sounds like you need to replace your fuel sending unit.
JOE55 is offline   Reply With Quote
Old 02-28-2008, 07:57 AM   #5 (permalink)
well, since mine still is accurate when it gets low (or at least reads conservative), I won't bother with it.
Old 02-28-2008, 02:26 PM   #6 (permalink)
Can't it be just the gage that isn't precise or stuck.
I think I had read somewhere that someone had adjusted how the needle in his gage goes up.So it would be at the full level instead of being at the lower line.
Old 02-28-2008, 05:47 PM   #7 (permalink)
Musikmann's Avatar
Good point here I think Oliver. I ran out of gas once in my life and that was enough. If it's accurate enough to prevent that, so be it.
Old 02-28-2008, 05:51 PM   #8 (permalink)
Musikmann's Avatar
I guess it's possible that the needle sticks, needs to be re-calibrated, or is dragging along the clear covering because it became mis-aligned. This might be worthy of a search, but I only remember the "replace the sending unit" fix already mentioned.
Old 02-28-2008, 08:31 PM   #9 (permalink)
Kajtek1's Avatar
Vehicle: E300DT/320cdi ML320/55
Have never seen reliable fuel gauge in my life. I always set daily meter at fill up and drive by it. When I get new (for me) vehicle I usually take a full fuel can with me and drive on reserve. Diesels don't like to be run dry, but I ran on reserve light for 60 miles and when I need it, I know I am safe on reserve for at least 50.
Kajtek1 is offline   Reply With Quote
Gauge issues weoner W123 E,CE,D,CD,TD,TE Class 7 11-15-2007 02:02 AM
Changed my fuel pump to fix my fuel gauge, and got an added BONUS. mikewired W163 M-Class 12 11-10-2007 09:49 AM
Problems fitting 500 fuel gauge-oil pres'-water temp gauge cluster to 560 clocks mutley666 W126 S,SE,SEC,SEL,SD,SDL Class 2 10-10-2005 10:03 AM
Update on Fuel Gauge Problem: Got Fuel Pump Replaced Today tjhsiao W163 M-Class 4 10-25-2002 05:47 PM
MB issues bulletin on '02 ML fuel gauge problems.... Andy-Montreal W163 M-Class 13 08-29-2002 09:47 PM
