Old 02-27-2008, 03:07 PM   #1 (permalink)
MFK
Date registered: Jan 2008
Vehicle: E200 Kompressor 2001
E200K Water leaking into boot
When I wash the car and then open boot lid water flows out of the rear of the rear of the fog lights or boot lock and into the boot. Any idea where this could be getting in. I have removed the inside trim of the boot lid and used a torch to see if I could see gaps but nothing obvious. all the rubber seals around boot edge look good. The boot is not wet it only happens when I lift the lid and it pours out
Cheers
MFK
MFK is offline   Reply With Quote
Old 02-27-2008, 03:16 PM   #2 (permalink)
ohlord's Avatar
Check
for plugged drains.If dirt or leafy material plug them up it could be trapping a bunch of water.
ohlord
ohlord is online now   Reply With Quote
Leaking Boot paddyb W202 C-Class 0 01-20-2006 09:07 AM
Water found in both sides of the boot w140benz W123 E,CE,D,CD,TD,TE Class 6 11-10-2005 05:00 PM
water leaking in.... ai_SLK R171 SLK Class 8 03-12-2005 05:07 PM
WATER IN BOOT 560sec alanr W126 S,SE,SEC,SEL,SD,SDL Class 3 11-20-2003 06:35 PM
Help: water ingress into boot lid! ianx, manchester R170 SLK Class 3 07-28-2003 04:32 PM
