Old 02-25-2008, 07:35 PM   #1 (permalink)
Date registered: Feb 2008
Vehicle: E430
Child tangled in rear seat belt, need to replacement; seat belt, of course.
Hello everyone,
This is great site, I am new to the forum (1999 E430) and this is my first posting. I noticed a lot of friendly and honest advice. Here's my story:
Last night, after a two hour trip, my child somehow got tangled up in the rear seatbelt. I assume she put the strap behind her, lay down, got up and God knows how else she moved.
So, when we finally got home, she unbuckles her seatbelt and it retracts to the point where we could not make the seatbelt come out, it only kept retracting.
I turned the car off, open, closed the doors, re-started the vehicle, pressed the break pedal several times. Nothing worked. It got to the point where it was too tight for her to slip through it and I was affraid she would start to suffocate. I took a knife and sliced the seat belt like scotch tape.
Any ideas as how to relpace it (DIY)? Cost?
I even took the seat out before getting my child and did not see a viable way to get her out but by cutting the seat belt.
Thanks in advance for any help/advice.
oalejandro is offline   Reply With Quote
Old 02-26-2008, 06:24 PM   #2 (permalink)
Date registered: Feb 2006
Vehicle: 2001-W210-CAPRI METALIC BLUE-
Cool Picey
Try a used part provider..
I like Potomac German Auto for quality.
Ask for Pat.
B
The finest example of automobile engineering in the world
Floats like a CADI
Stings like a BMR
Stingy as a Prius
and.... all Mercedes Benz.
MRBSMITH is offline   Reply With Quote
Old 02-27-2008, 05:01 PM   #3 (permalink)
Vehicle: 2004 C230 Kompressor Sport Coupe
Every German car I've been in newer than 1985 has had this feature. If you pull the belt out all the way, it'll go into a mode where it only retracts until it has been put all the way back. As far as I can tell, it's intended to help you fasten down child seats.
zeet is offline   Reply With Quote
Converting lap belt to three point seat belt suttree G-Class 3 06-09-2007 11:34 AM
seat belt pre-tensioners and seat belt slack snik W140 S-Class 4 05-03-2007 09:26 AM
Seat belt clip replacement sdiianni W124 E,CE,D,TD Class 4 01-27-2007 05:32 PM
driver's seat belt replacement 560sec_vroom W126 S,SE,SEC,SEL,SD,SDL Class 3 11-23-2005 02:20 PM
Front Seat Belt Replacement...Battery Disconnection?? ronan95d2 W140 S-Class 3 09-27-2004 08:58 AM
