» Featured Product
» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W210 E-Class
Old 02-17-2008, 07:49 PM   #1 (permalink)
~BANNED~
Date registered: Sep 2007
Vehicle: "Why so Serious, Son?" 1998 E320 Wagon
Post DIY Water Pump & WIS
Hi guys!
Well here it is! The Latest in my DIY exploits. Please proceed with caution. This is how I did it and I assume no responsibility for how you do it. I attached a DIY explanation and the WIS as well. For M112 Engine and M113 Engine.
Enjoy!
Drew
TNTRower is offline   Reply With Quote
Old 02-18-2008, 09:02 AM   #2 (permalink)
G-AMG's Avatar
Date registered: Oct 2005
Vehicle: '04 G55 '80 280GE '99 S420 '98 E320 2010 E350
TNT,
Very nice contribution!!
May I ask, "What prompted you to change the pump out??" Were you having some problems?
G-AMG is offline   Reply With Quote
Old 02-18-2008, 09:26 AM   #3 (permalink)
~BANNED~
Very good question
I was doing a weekly "look around" under the hood with the engine running. I noticed that the serpentine belt was wobbling. That is NOT a good thing. I trouble shot it with some help from the folks here. Just search for some posts about water pump. My threads will come up.
At any rate I am glad I did because you can see the scoring that happened with the loose bearing. The shaft was wobbling and would skim the pump wheel on the engine block.
Old 02-18-2008, 11:10 AM   #4 (permalink)
ohlord's Avatar
Vehicle: 1999 E320 Wagon,2000 E 320 Wagon, MGB Track/Rally, 94 Subaru Wagon ,1988 300E ,more....
Great
write up
I am sure it will get stickyfied
Thanks for taking the time to do such a professional DIY workshop article.
Old 02-18-2008, 12:36 PM   #5 (permalink)
Date registered: May 2005
Vehicle: '07 GL320CDI, '06 E320CDI, '06 350SLK
You should indicate that your procedures are for M112/M113 engine (E320/E430).
Other engines installed in USA W210 include M104 (inline 6) and M119 (early V8=E420)
Your procedures should be applicable to most M112/M113 installations, not just W210 installations.
Here are links to information about the two Mercedes special tools required--no one but you is ever going to find these on eBay:
http://www.startekinfo.de/etools/con...3 589 00 01 00
http://www.startekinfo.de/etools/con...3 589 00 40 00
There is no such thing as "star nut sockets." What's required is external Torx sockets, and assuming your sizes are correct, the true size names are E10, E12, and E14. A nice set of these is available here: Sockets Sets 1/4" & 3/8" Drive Bit Sets From Wiha
Just some "editing" by a retired technical writer!
Kent Christensen
Albuquerque
'07 GL320CDI, '06 E320CDI, '06 SLK350
Old 02-18-2008, 01:32 PM   #6 (permalink)
~BANNED~
Thank you
Kent appreciate the editing. Just as an FYI the "Star Nut Socket" was an error. The label on the package says "7pc. Star Socket Set." In the specific step by step you will see that they are labeled as "E10" and such. As for "no such thing as 'star nut sockets.'" if you do a search for "Star Sockets on e-bay you get a whole lot of returns. Boy I am glad that we have folks on the boards here that are willing to provide feedback!
As for labeling the DIY for the various engines thanks for the info. I did not know which engines it would work for but now I and everyone else does.
Drew
Old 02-28-2008, 01:43 PM   #7 (permalink)
~BANNED~
And by the way never underestimate the benefit of a weekly look around while the engine is running.
Old 05-27-2008, 11:24 PM   #8 (permalink)
Date registered: Aug 2005
Vehicle: 2001 E320
TNTRower,
Did you torque each bolt? or did you just hand tighten them?
Thanks.
(I'm going to replace the water pump for a 1999 E320.)
cerritos is offline   Reply With Quote
Old 10-23-2008, 11:04 AM   #9 (permalink)
C230 Sport Coup's Avatar
Date registered: Feb 2007
Vehicle: 2002 C230 Sport Coup
Any chance of sourcing wrenches like this at a local shop?
Duh, I started the job, (big mistake) and THEN found your DIY.
I originally searched on ML320 and water pump and got nothin' till I got smart and searched on m112 and water pump.
Unfortunately I've already got it torn apart.
I see them on ebay, but looks like it'll be a week before I can get them.
Hopefully the local PD won't tow me before that.
2002 C7 Orion Blue 2.3L C230 Coupe 240HP
Auto-Pano-Oyster Leather-Audio 10
AMG Front bar 22mm-17" Wheels- C32 Brakes- H&R 19mm rear sway
ASP Pulley-Supercharger Muffler Deleted- NGK BCPR7EIX-11
Supersprint Header-Magnaflow Cat- AR20 Resonator- Remus Muffler
MAF Screen Delete- TB Screen delete
TEIN SS Coilovers -
Clear sides- 2005 tails, Blinkers & Grill- Tinted Windows
Bi-Xenons-Clear Fogs- Clear Side/Stealth Bulbs
Renntech Spoiler
C230 Sport Coup is offline   Reply With Quote
Old 10-23-2008, 05:52 PM   #10 (permalink)
Hell yeh! Thank god for google.
I found this thread, when I searched on water pump and M112 !
Thanks to all, major Kudo's for the pdf's, thank you, thank you, thank you!!!!
I was lucky, my local indy MB guy loaned me his special wrenches...
I did find them on ebay...but I'd be waiting for a week!
So, my GF's ML320 is back on the road...as best as it can be at 187.5K miles!!!!
Wow, it was a beeotch of a job. I was trying imagine if I was a pro mechanic, and then they say, OK great, here's the next work order.
F that! Man, I hit the hot tub and 2 beers later I think I'll survive.
I replaced my Supercharger and alternator and there were less bolts to
R&R than on this job!
Thanks to Rick at Rick's Mercedes in Scotts Valley for the much needed loan of the wrenches and the correct parts!!!
Many many thanks!
WATER PUMP DIY ANYONE? Alejo123 W163 M-Class 10 02-08-2010 10:23 AM
WIS for Water Pump? TNTRower W210 E-Class 1 01-25-2008 03:38 PM
92 400E Power steering pump and water pump, need advice kanio W124 E,CE,D,TD Class 5 03-19-2007 05:58 PM
Water Pump R & R The Melmaan W201 190 Class 4 12-30-2006 10:10 AM
Windshield Water Pump DIY? 97C28O W202 C36 AMG, C43 AMG 1 08-22-2006 09:38 AM
