I have a '98 E320 with 100K. I love the car, but one little problem is very irritating. The steering column housing (between the wheel and the dash) moves whenever you use the turn signal in mild or warm weather, but not when it is cold. Is there a simple way to correct this? Like I said, it's not a big deal, but it is very irritating! Appreciate any ideas.
Hemersam
There was a recent thread on this issue awhile back on site below.
Essentially, the stalks for wipers, turn signals, cruise control, etc. are attached to the column with a band which is tightened with a screw. After removing the air bag, steering wheel and plastic sleeves, you can access the screw and tighten it.
Thanks, Richard for answering with the great set of pictures showing how to fix this "problem." However, after seeing the work involved (I'm sort of an amateur, you know, the kind who take their car to the shop after they've screwed it up. I think I'm going to let the thing turn for a spell and see if it gets worse. Thanks again. I do appreciate it.
Hemersam
You are not alone That makes two of us
W210 1996 E320 Exterior Smoked Silver, Interior Mushroom.
Bought Jan 2008 with 130K. Now 143 K miles as of 11/09/08.
Make it very easy. It took me a total of 1 hour with a beer break. I did it by myself and wedged a 2x4 between the steering wheel and floor so the wheel would not turn when I broke the retainer nut free. If you are willing to drop $500 on the repair then by all means take it in. IMHO letting it sit is not a good idea with all those wires in there. Follow the repair wiki and don't "punt" when it comes to the tools. After you do it you will be amazed at how your confidence level increases with repairs.
__________________ Who's John Galt.
"Timeo Danaos et dona ferentes" - Virgil, The Aeneid, Book 2
