First I like to say hi to everyone from sunny Costa Rica.
I like to ask for help if I can.
I have 1998 E320 with 55,000 miles. Runs and looks great.
Recently my ASR warning light comes on then it switches to BAS. Then stays on. The car still runs like nothing happen. Still fast no other symptoms at all.
I can go for days with aggressive driving and nothing happens, then other day I go very slow and the ASR then BAS light comes on for no apparent reason.
I have spend hours searching forums and it looks like many people having the same problem. Mine is different because it doesn't go in the limb/slow mode at all. it has full acceleration etc.
Most answers are:
Faulty brake switch (I tested this one and looks fine). How? Press the bake pedal and start the car, keep it pressed for 3 minutes and release the pedal, if the ASR light on comes on = faulty switch = change it!
(not my case)
Then it could be alignment (that will have the light on every day)
not my case
Dirty sensors (again light will come on every day)
not my case
Anything else that anyone can suggest?
Or I can just bridge pin #1 to pin #6 and the light should go away.
Any other suggestions? (no I haven's run the scan yet)
TIA
~ George
190 -SOLD
190 2.6 - SOLD
230 Kopressor - SOLD (great car)
300E - SOLD
ML500 - SOLD
E320 Daily driver
Porsche 911 Turbo
Porsche 930 Turbo
Brake Light Switch. I had the same symptoms, and very intermitant. I installed a new switch (they are actually quite inexpensive) and no problems since.
Even if it is something else, I guarantee you will need a new switch in short order.
BTW, We just returned from Costa Rica. Rented a friend's house on the mountain overlooking Tambor.
Lovely country and the nicest people. I am jealous.
We were there for two weeks and it was not enough. I cannot wait to return.
Next time we will not drive from San Jose, in preference of Sansa air.
One question though, how does one keep a car clean with all of those dirt roads and dust?
George:
Just to reinforce the brake switch concept.
When I purchased the car the PO mentioned that "A couple of times the computer totally glitched, lights, warnings, etc." each time he pulled over shut off/restarted and all was well.
Jump forward, Soon after buying the car I was driving my wife and friends to Manhattan for a show.
Lots of stop/go traffic and the same thing happened.
After we parked and returned from the evening, all was well.
A week later I installed a new switch and there have been no episodes for over a year.
It can be VERY intermittant.
I hear CR is peaking and Guatamela is the next steal.
Did the battery trick. =
disconnected battery
pressed the brake pedal 30 plus seconds
reconnected battery
centered steering (moving all the way from left to all the way right)
reprogram rest of the car (radio, roof, windows etc.)
WORKS so far. No light last two days.
Looks like it's fixed.
