Old 02-01-2008, 09:17 PM   #1 (permalink)
Sergio's Avatar
Date registered: Sep 2002
Vehicle: 1995 E320
Tranny vs. transfer case fluid change
Hi,
There are plenty of posts that recommend tranny fluid changes well before 100K miles.
For those of us 4-Matic owners, what is the recommendation for transfer case fluid changes? Since both the tranny and the transfer case use the same type of fluid, would the same replacement interval apply?
I read the WIS BS last night and of course it says "sealed for life."
Your opinions are appreciated!
Sergio
'95 E320 SE
'99 ML430 (gone)
'01 E320 Wagon 4-Matic
'94 C280 (R.I.P)
Sergio is offline   Reply With Quote
Old 02-01-2008, 09:28 PM   #2 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
There is a procedure for changing the transmission fluid. Is there one for the transfer case?
Old 02-01-2008, 10:15 PM   #3 (permalink)
Sergio's Avatar
Vehicle: 1995 E320
I don't think so but my procedure will be: insert a plastic tube, vacuum the fluid out (I have an electric pump) and replace with new tranny fluid. The most difficult part, since I have a wagon, is accessing the fill plug on the transfer case.
Old 02-01-2008, 10:17 PM   #4 (permalink)
If it were my car, I would do it. That is a very expensive transfer case. Of course, I've never in my life heard of a cheap transfer case.
Old 02-02-2008, 05:43 AM   #5 (permalink)
Date registered: Jan 2007
Vehicle: 2005 S500 4matic Sport Designo
Shouldn't be TOO difficult. I had zero problems accessing my drain/fill plug, but I don't have a wagon.
Give it a shot, its only about a liter in there. I doubt you'll get more than 500ml out, but as with the tranny, some dillution is better than none.
OliverK is offline   Reply With Quote
Old 02-02-2008, 06:44 PM   #6 (permalink)
Franasia's Avatar
Date registered: Jan 2005
Vehicle: 2000 E320S4 210.282
Sergio,
I am looking to do it in the near future. Forum member loubapache came up with the answer to the location of filler plug on transfer case. There's no drain plug. I have the wagon and it appears it's got the balancer that appears to be unique unique to wagons and adds some more work.
This is the thread where it was discussed:
http://www.benzworld.org/forums/w210...uestion-2.html
Cheers
“Design embodies the values of a company. Even if there were no star, the car must always be recognizable as a Mercedes-Benz.” Peter Pfeiffer, Daimler AG
Franasia is offline   Reply With Quote
Old 02-02-2008, 07:07 PM   #7 (permalink)
Sergio's Avatar
Vehicle: 1995 E320
Cheers
Thanks. I've seen that post and will use it as a guideline.
Today I replaced the tranny fluid and was disappointed to only remove just over 3 quarts. I'm used to my W124 where I can get the vast majority of the fluid out. I will run the car for about 5K miles and drain it again without replacing the filter. Will do this a couple of times and then every 40-50K I will drop the pan and replace both fluid and filter.
I also replaced both differential fluids. The front one is a similar situation to the transfer case (filler hole only).
Transfer case fluid change cmitch W163 M-Class 101 12-02-2008 08:44 PM
My Transfer case fluid change experience sstomcat W163 M-Class 8 05-30-2007 09:56 AM
Is The tranny fluid and transfer case fluid the same thing? DETANE W163 M-Class 4 05-12-2007 02:58 PM
Transfer case and differential fluid change questions Michael Pillay W163 M-Class 14 06-02-2006 11:07 AM
Transmission/transfer case/diff fluid change? anyone have this done? MLnoob W163 M-Class 4 10-04-2004 10:37 PM
